Fuse Wire - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 3rd June 2013, 07:38 AM   #1
Naidu is offline Naidu  Singapore
Default Fuse Wire
I need a short length of 2 amp, quick blow fuse wire. Can anyone tell me where I can buy this. Thanks.
Rgds,
Nara
Old 3rd June 2013, 08:01 AM   #2
Mooly's Avatar
I have never seen "fast blow" fuse wire sold by "length". Would a fuse holder and fuse not be more suitable ?
Old 29th August 2013, 10:19 AM   #3
d3imlay is offline d3imlay  United States
I don't know where to find it but have seen it used. The "water fuse" was a piece of 10A (I think) fuse wire wrapped around a stud type fuse block. When immersed in a bucket of water it was good for more than a hundred amps.
The application was troubleshooting inverters in the 5-30kva range. When a fault developed in the inverter (blown SCR) The water fuse would clear very fast. It saved replacing fuses at $50 or more until the inverter was repaired. I haven't seen this technique in years and would probably be forbidden with todays safety procedures.
Old 29th August 2013, 11:15 AM   #4
JonSnell Electronic's Avatar
24guage tinned copper solid wire is rated at 2Amps as fuse wire. Normally hand wired fuses are slow blow if coiled and fast blow if straight.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 30th August 2013, 09:10 AM   #5
Default Fuse wire
I solved this long ago, bought a glass fuse of the required Amp, broke the glass and soldered it between the 2 posts on the circuit board, working fine.
Rgds,
Nara
Old 30th August 2013, 09:16 AM   #6
Just to qualify "Fast Blow", that means faster blowing than slow blow but NOT ultra fast blow. A bit like BS1362, (the fuse will blow instantly at 10 times the rating).
Old 30th August 2013, 10:51 PM   #7
Jsixis is offline Jsixis  United States
nice to know as 90% of what I do is 2 amps or less
Fuse Wire Naidu Parts 6 4th June 2013 04:18 AM
Fosgate amp blowing power wire fuse Methodsofmahan Power Supplies 3 13th March 2012 04:32 AM
AC hot wire to fuse or switch first? gyrene Power Supplies 3 23rd January 2012 12:20 AM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
amp rating for fuse and fuse holder? riotubes Parts 5 27th August 2006 03:10 AM
Copyright 1999-2017 diyAudio
