Crossover potting - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 6th April 2013, 11:01 PM   #1
Default Crossover potting
The electronics-grade RTV silicones are too $$$ for me. If I use a standard acetic acid- or ammonia-cured silicone caulk (GE I or GE II, respectively), would I be hurting my MOX resistors, plastic-wrapped caps, or magnet wire?
Old 8th April 2013, 08:59 PM   #2
Anyone? I would rather not have to deal with a mess of hot glue.
Old 13th April 2013, 04:45 PM   #3
PChi is offline PChi  United Kingdom
I stuck my Crossover components down to a PCB using the standard DIY clear silicone sealant which I think was the acetic acid type stuff and 15 years later no problems. I didn't ecapsulate them I just stuck all the compoents down to prevent rattles.
The Crossover components were from Falcon Acoustics and used Polypropylene Capacitors. The inductors were just the standard rather crude ferrite rods wound with wire that self sticks together with heat I guess. From memory the resistors were just ceramic bodied.
Old 13th April 2013, 04:52 PM   #4
FWIW I have used paraffin wax with quite some success... A small bonus is that if things go sideways or if you just want to switch out a component in the future all you need is heat.
I have seen the acetic acid based silicones turn copper coils GREEN over time.
Old 13th April 2013, 06:01 PM   #5
I took the drive units out so I could see the crossover. The components have been stuck to the PCB with silicone sealant though it isn't obvious on the picture attached.
The silicone sealant isn't really in contact with the lead out wires so corrosion hasn't been a problem.
Potting transformers Burnedfingers Tubes / Valves 10 5th June 2017 04:38 PM
Toroidal transformer potting can jamesjung21 Tubes / Valves 13 20th February 2008 12:04 PM
Potting and sheilding transformers pjpoes Parts 1 8th March 2005 07:58 PM
neophyte - transformer potting ofb Tubes / Valves 13 13th December 2004 09:03 AM
Old Tranny Potting Material audiopro Tubes / Valves 6 8th June 2004 10:27 AM
Copyright ©1999-2017 diyAudio
