ADC and DAC sampling pc card with possibility to disable digital filters - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 5th April 2013, 05:27 PM   #1
BKSL is offline BKSL  Slovakia
Default ADC and DAC sampling pc card with possibility to disable digital filters
Please recomend sampling ADC, DAC pc card with possibility to disable input and output digital filters and any other calculation of signal.
Range 0 Hz - 192 kHz. Minimum 16 bit resolution.
Purpose is exact mesurement of AC/DC signal.
Old 6th April 2013, 03:44 AM   #2
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
I'd like to know also.
-RNM
Old 6th April 2013, 06:56 AM   #3
Then let's focus on this. To exactly sample/measure signals we have to avoid aliasing, or else the waveform will suffer very serious distortion in the presence of out-of-band signals. So low-pass filtering is an inherent need for what you're trying to achieve. Digital filters are much better suited for anti-aliasing, due to the high filter order required here. That's why about any contemporary audio ADC involves digital low-pass filters, and it doesn't seem a good idea to me to bypass them...
Samuel
Old 6th April 2013, 09:14 AM   #4
Problem is that analog and digital filters shift phase and amplitude in nonlinear manner. Then it is not possible to reconstruct original wave from DAC to ADC conversion.
I need send signal to speaker throught DAC and then i need to acquire signal throught ADC of speaker real exact amplitude in exact time.
If i set correct sampling rate of DAC and ADC with the same clock source then i do not need filters. I must only set exact delay between DAC sampling step and ADC sampling step to obtain amplitude of "still state" of DAC conversion.
Old 6th April 2013, 10:04 AM   #5
I don't understand the issue--a good digital filter has no appreciable phase and amplitude deviation in the audio frequency range (particularly if you're doing acoustic measurements--the errors of the DAC/ADC will by several orders of magnitude below the effects you're measuring!). There is some group delay (usually a few ms), but you can easily compensate this in software.
If I set correct sampling rate of DAC and ADC with the same clock source then I do not need filters.
Why not? Aliasing will still occur, and the prevalent sigma-delta architecture still needs downsampling filters...
Samuel
Old 6th April 2013, 10:20 AM   #6
dmills is offline dmills  United Kingdom
That shows a certain misunderstanding concering the nature of correctly designed sampling systems (Analog or digital it matters not), you might want to review some modulation theory.
What are you actually trying to do? What problem are you trying to investigate?
A data aquesition card from national instruments or someone whould give you what you seem to think you want, but I am fairly sure it is the wrong answer to whatever you are actually trying to do.
The anti aliasing/reconstruction filters are not optional if you want a DAC or ADC to actually work in terms of reproducing the band limited signal accurately, your signal labelled 'analog signal from dac' is really nothing of the sort, the analog signal starts when you apply the reconstruction filter.
Almost all modern converters are delta sigma devices that use short word length converters run at high multiples of the 'sampling rate' together with feedback and digital interpolation/decimation filters to do the job.
Regards, Dan.
Old 6th April 2013, 10:21 AM   #7
Originally Posted by Samuel Groner View Post
... There is some group delay (usually a few ms), but you can easily compensate this in software.
Group delay is not acceptable. All frequencies must be presented in correct phase as original.
I done some measurements. With active filters is not possible to fight with different group delay for different frequencies.
Old 6th April 2013, 10:53 AM   #8
Originally Posted by dmills View Post
... your signal labelled 'analog signal from dac' is really nothing of the sort, the analog signal starts when you apply the reconstruction filter.
Ideal reconstruction is possible only with big hardware update, in future :-).
We will need to multiply sampling speed and sampling resolution. Analog "staircase" step on output DAC side will be lesser than value of last bit of input signal to reconstruct.
Example: 16bit 48 kHz signal will be rendered only digitally by real 32bit and 2304 kHz sampling. That will be nice. But now it is not possible and i need to bypass filters.
Purpose is digitally control amplitude of loudspeaker to reduce his THD.
Something like in attachment but with a little bit different principle.
Old 6th April 2013, 11:11 AM   #9
jan.didden's Avatar
The referenced patent is for feedforward correction.
If you want to do that, the delay is irrelevant. You'd have the original signal in digital format, run it through the DSP, apply correction and then send it out to the DAC & speaker.
If, what you want to do, is actually closed loop feedback you will ALWAYS have delay whether you use filtersd or not. Google 'latency'.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 6th April 2013, 11:49 AM   #10
Yes, constant delay of all frequencies is irelevant. It will be set easily.
But group delay vary with concrete frequency.
In my principle are 2 stages only. First is calibration only. And second is only playing "calibrated" signal with no feedback. Therefore no feedback with low latency is needed.
Safe Mode and disable onboard for sound card? fakeout PC Based 3 16th August 2012 12:36 AM
PC Down-sampling / Up-sampling / Asiodrivers / Asynchronous streaming Explained BIA Software Tools 0 1st July 2012 01:06 PM
PC Sound Card as basis for DIY DAC georgebrooke PC Based 7 12th April 2011 07:08 AM
DAC from PC audio card gainmona Digital Source 7 13th February 2005 09:56 PM
Gameboy Digital Sampling Oscilloscope 10kv Equipment & Tools 0 8th February 2002 01:09 AM
Copyright ©1999-2017 diyAudio
