| Equipment & Tools From test equipment to hand tools |
#101 |
Well I would gladly see an ADC replacement in the qa400.
Proprietary software if it's not bugged is not that bad... Btw anyone knows or has used one of the Aaronia spectran devices?
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#102 |
I have tried 7-8 of the semipro cards and the RME and they all have problems. The ESI Juli@ seems to have the most benign interface and give the most consistent results. But its noise floor is not what it should be. I use it with the demo boards to get what I want. And you have a desktop computer on the back side. I can see making a replacement analog module for the ESI but a portable solution would be really great.
I posted some measurements showing what is possible with the AK5394A.
Demian Martin Product Design Services |
#103 |
Not so simple to do. They used a codec.
David. |
#104 |
Demian, do you want to try the yellowtec puc2?
#105 |
I would not mind playing with one. just have no interest in spending more money on this stuff.
I looked into it. It seems to need drivers and run on an Atmel AVR32. The AudioWidget runs on an AVR32 and is fully UAC2 compliant. I'm pushing for a Digital input. Hopefully soon.
#106 | |
I notice that in the first schematic where you say it is the original; the op amps are all OPA-827s and the final is JRC2068s. I realized that there has been some gain scaling but did you also swap out the op amps? Just curious. Thanks Matt |
#107 | |
No I didn't swap op amps. I just gabbed something from the symbol lib to use for the schematic. Next time I use the generic op amp to avoid confusion. I see no need to change the op amps. The results are good as they are.
David. |
#108 | |
Tracker Pre on Windows XP SP3 runs at up to 192 kHz fine for me for years.
/S Quote:
#109 | |
Strange, people on thos board have measured the EMU1212m with much better results. See attachments.
/S Quote:
#110 |
Here are a few of my own Tracker Pre measurements in loop back I did in 2011. Both with 48k and 192k. 48k gives lowest THD. 192k is only for testing.
Still not good enough. /S |
| ICEPower 125ASX2 Measurements and Mods | stokessd | Class D | 6 | 26th December 2012 03:31 PM |
| FFT, now even faster | benb | Everything Else | 9 | 19th January 2012 05:21 AM |
| D/A preamp FFT measurements for review plz | zigzagflux | Tubes / Valves | 30 | 10th March 2011 03:21 PM |
| what is an FFT graph? | keantoken | Everything Else | 23 | 10th September 2006 12:13 AM |
| Distortion measurements using FFT software on PC/Mac | peranders | Everything Else | 1 | 22nd April 2003 11:21 AM |
