QuantAsylum QA400 and QA401 - Page 115 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 1st July 2014, 06:41 PM   #1141
jan.didden's Avatar
Yes I noted, in fact I subscribe to that thread.
It's just that right now I have another priority, but I have the same ideas to cut out some of the ss switches and the DC-opamps.
One issue I still am unsure about is how fast the autoranger needs to/can react. I guess I would still need the full range input protection for the soundcard this thing is going to feed. I'll burn that bridge when I get to it
Jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
Old 19th July 2014, 12:52 AM   #1142
1audio is offline 1audio  United States
I finally stepped up to the plate and ordered the PCB's to see if they will work. I made one last minute addition to the design. I added LME49610 buffers on the bottom of the board for the outputs. They are set up so they can be easily bypassed but I wanted to try them and see if they can enable a 50 Ohm drive in this.
Boards next week. Maybe some partly working boards soon after.
Demian Martin
Product Design Services
Old 19th July 2014, 08:38 PM   #1143
FdW is offline FdW  Netherlands
FdW's Avatar
Cool, looking forward to this
Old 19th July 2014, 11:40 PM   #1144
dirkwright's Avatar
Is the chip inside the feedback loop?
I'm sure this can drive 50 ohms, no problem, but better if inside feedback loop. I use the BUF634 to drive 32 ohm headphones all the time. I used the TO-220 version with a big heatsink. No problems at all.
Old 21st July 2014, 06:40 AM   #1145
The buffer is inside the loop. Its designed to be used that way. I will be interested in how it all actually works once its all together. Datasheet promises .00005%. I won't expect that much from this. The goal is 3V open circuit and 1.5V into 50 Ohms but I'll check the board with 18V supplies with a goal of 7V into 50 Ohms (200 mA Peak)
Demian Martin
Old 22nd July 2014, 02:24 AM   #1146
dirkwright's Avatar
It'll probably get hot driving 7V into 50 ohms.
Old 22nd July 2014, 04:45 AM   #1147
The USB supply won't support 10V peak into 50 Ohms anyway. However for other possible projects with soundcards this may show some good options.
I prefer 50 Ohms when possible since cables, loading and stray cap won't alter the frequency response to any extent.
Demian Martin
Old 22nd July 2014, 04:48 AM   #1148
davada is offline davada  Canada
What about 75 ohm or 100 ohm?
David.
Old 22nd July 2014, 04:55 AM   #1149
I have a lot of 50 Ohm stuff. It will have the lowest noise as a source plus it will have the smallest error when loaded. Going up from 50 Ohms is easy.
Demian Martin
Old 22nd July 2014, 04:57 AM   #1150
Good reason.
David.
QuantAsylum 401 & 405 B&W_arthur Equipment & Tools 5 22nd March 2016 05:27 PM
QA190 and QA400 Gains sgtnoah Equipment & Tools 4 17th July 2015 04:46 AM
Question on QA400 Alan0354 Equipment & Tools 7 10th July 2015 07:34 PM
FS QuantAsylum QA400 audio analyser jan.didden Swap Meet 3 29th September 2014 06:10 PM
New Quantasylum QA190 Differential Input Probe stellavox Equipment & Tools 3 20th March 2014 07:06 PM
Copyright 1999-2017 diyAudio
