QuantAsylum QA400 - Page 51 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 19th November 2013, 06:57 PM   #501
1audio is offline 1audio  United States
I think this will illustrate what I'm asking:
Demian Martin
Product Design Services
Old 19th November 2013, 08:31 PM   #502
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
The gen used was a 600 Ohm output Z (HP 339A)....
-RM
Old 19th November 2013, 09:57 PM   #503
The point being that the QA400 etc. will introduce distortion at its input. You can measure the distortion introduced by the input of the QA400 (or whatever) with this test.
Demian Martin
Old 19th November 2013, 10:10 PM   #504
RNMarsh's Avatar
I will do that test and let everyone know if any change due to QA400 input loading and put up data here.
Thx-RNMarsh
Old 20th November 2013, 06:39 AM   #505
RNMarsh's Avatar
Default comparison A-P vs QA400
Using the ShibaSoku AG16 source (600 ohms/.7v rms), the QA400 added .0001% THD+N when applied in parallel with Audio-Precision 2722.
That is when the QA400 is in data acquisition mode... when halted and you have only the screen capture display, the THD+N is 2-3%.
The AG16 shows on the A-P as only having 2H and 3H at about -120dB and nothing above the noise floor of -135dB above those two harmonics.
The QA400 however, shows a lot of harmonics and extrainious freqs beyond the first two harmonics and shows the 2H and 3h at a higher level than the A-P.
RNM
Old 20th November 2013, 12:47 PM   #506
If the "stock" '400 input and output stages may be the "weak link" in an otherwise excellent product, how about adapting/modifying the outboard I/O stage that Demian has already developed to "tap into and replace" the stock I/O amps?
Charles
Old 20th November 2013, 01:37 PM   #507
jan.didden's Avatar
It may be enough to make sure the QA400 input is driven from a very low impedance, i.e. a buffer.
Many opamps show somewhat nonlinear input impedance and that may become a factor at the very low distortion levels we are looking at here.
Possible Demian's interface is better in this respect?
Jan
Whether we like to think of it this way or not, an audio engineer shares the professional goal of a magician - Richard Heyser
Check out Linear Audio!
Old 20th November 2013, 02:15 PM   #508
davada is offline davada  Canada
I suspect the ESI chip and possibly the input blocking capacitor. it would be interesting to see
what we have with these parts removed or replaced.
David.
Old 20th November 2013, 04:36 PM   #509
jan.didden's Avatar
David, what is this ESI chip - is it the input opamp/buffer or what?
jan
Old 20th November 2013, 04:55 PM   #510
I saw the input induced distortion as well. The interface reduces it but has a similar problem of its own. However the interface does reduce the extraneous spurs.
Adding a buffer/driver to replace the one on the board could work but its still more stuff to deal with. That only makes sense when the interface is inside the box. Connecting flying leads to holes vacated by the BNC connectors is easy. Flying wired to pads on surface mount PCB's demands an additional level of skill. Also, ideal would be an integrated diff in to diff out solution like the one I'm using. Otherwise it will need a number of .1% resistors to have decent common mode rejection.
Demian Martin
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
