| Equipment & Tools From test equipment to hand tools |
#11 |
A decent router may be the most versatile power tool you can own. Get the plunge-base tool, then pick up the fixed base in the near future. The plunge base will be suitable for most cases where you move the router over a workpiece, while the fixed base is more suitable for mounting in a router table.
Ditto the comments about carbide bits with 1/2" shanks! I think even an inexpensive carbide-edged bit will outperform and outlast a comparable bit in tool steel. There are more good comments in the thread "Which Router?" at which router? I rather like this version of the pipe clamp, because of the greater depth, but I own both styles: http://www.leevalley.com/en/wood/pag...77&cat=1,43838 |
#12 |
Is this a decent bit to start with?
Amana Tool 46315 CNC Spiral Flute Plunge 2-Flute Up-Cut Solid Carbide Router Bit, 1/4-Inch Shank - Amazon.com |
#13 |
Depends on what you're using it for. I use those for plunge cuts, as for mortises. If you're cutting holes for speakers, I wouldn't use it. And don't buy 1/4" shaft, spend the dollars for 1/2". One of the best router bit companies is Whiteside Machine Company. In any of the tests I've seen, their bits are continually amongst the best, and most consistent - meaning you can rout more without the bit dulling.
#14 | |
I wonder if they will sell at any of the local shops around me... |
#15 | ||
Dale |
#16 |
I am doing a Lowes/HD run before I get started, any links to decent ones would be greatly appreciated! "Regular Straight Bit" meaning not spiral up cut but just a straight bit with two blades?
#17 |
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Try to get 1/2" shank bits. Larger diameter cutters with bigger bearings last longer. I like the shear cutting bits. Make sure you understand the concept of climb cutting and be sure to avoid it.
Evan
http://www.evancotler.com |
#18 | |
Yes, if you have to pay straight list price start with a straight-flute, carbide edged, bit with 1/2" cutting diameter, 1" cutting length, and 1/2" shank. Make sure it has cutting flutes on the END of the bit, so you can plunge it into a workpiece without starting at an edge or pre-drilled hole. (I think they all do these days, but that wasn't true in the past.) Then compare it to what you'd pay for additional features, such as a LOWER pilot bearing or spiral flutes, evaluate the fiscal WAF, and act accordingly. For reference, here's Rockler p/n 90550: http://www.rockler.com/product.cfm?p...5&site=ROCKLER . The basic straight bits are often used as loss-leader sale items but it's not unusual to find sale prices on bits with more features - for example, the Woodcraft p/n147239 at http://www.woodcraft.com/Product/200...CL-x-12-S.aspx Dale |
#19 |
So would this be something ideal to have?
Spiral Upcut Solid Carbide 1/2" Shank Buy Whiteside RU5150 Solid Carbide Spiral Upcut Router Bit 1 2 Sh 1 2 D 1-1 2 CL 3 OL at Woodcraft |
#20 | |
Thanks again! |
| Have a plunge router...now what do I need? | PoorSound | Multi-Way | 9 | 5th February 2008 03:08 AM |
| When buying a plunge router... | Cal Weldon | Equipment & Tools | 21 | 23rd February 2007 11:44 AM |
| Hitachi M12V 3.25HP 1/2" plunge router variable speed $160, free shipping | 454Casull | Equipment & Tools | 0 | 9th July 2006 05:42 AM |
| FS: Plunge router and Jasper circle jig | bsteeves | Swap Meet | 7 | 18th June 2003 05:29 PM |
