| Equipment & Tools From test equipment to hand tools |
I want to use 2-4 identical model vintage fieldcoil woofers in my system, 2 for the midbass horns and 2 for the stereo basshorns. Each fieldcoil has an impedance of approximately 5200ohms and can dissipate 25 watts. This website utility calculates the Voltage requirements for a given fieldcoil speaker (which in this case works out to 361V per woofer). Field Coil Power Module at Ted Weber's Site I'm looking for the right bench power supply with variable voltage and variable current. 1) My problem is I do not know how to calculate how much current (amperes) I need per woofer (?). 2) Also, I've read you can wire multiple fieldcoil speakers in Series to a single power supply provided the PS has enough current for the combined load. If I can wire up in Series the fieldcoil connections of 2 or 4 of these FC woofers, it could save me from having to buy a separate PS for each woofer. So these are the two reasons I need to know how to determine how much current a given PS needs to have to provide power to my 5200ohm 25watt dissipation FC woofers. Thank you in advance for any assistance. . |
#2 |
361V at 5200Ω, 361/5200=.0694 Amps. Aprx. 70 mA per woofer. It would be better to put the field coils in parallel than in series as you would need 722V at 70ma for two speakers or 1444V at 70ma for four speakers with the field coils in series. If you put the four speakers in parallel you would need a 361V 280mA (4*70mA) power supply, still deadly but 600V wire is a lot cheaper than 1500V wire.
| Power triode drive current requirements | MrCurwen | Tubes / Valves | 17 | 28th October 2010 08:49 PM |
| Power Supplies - Requirements | java | PC Based | 24 | 16th October 2009 06:27 AM |
| Bench PS: stacking DC supplies | ErikdeBest | Tubes / Valves | 2 | 6th March 2009 02:00 PM |
| High Current Power Supplies | matt_uk | Solid State | 13 | 11th October 2004 08:49 AM |
| High current DC power Supplies | fr0st | Parts | 7 | 27th April 2003 03:28 AM |
