Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 8th January 2013, 06:32 PM   #1
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Default macbook and mic for measurement
Hello,
I'm about to acquire my first mic and speaker measurement setup. Here's what's on my list:
A DIY mic based on Panasonic WM-61A cartridge (what's the best source in EU with specific calibration files?)
A mic preamp based on this PCB Mad About Sound | Microphone Preamplifier PCB v1.1 (I just realised that store is not trading anymore, so all other suggestions are welcome)
I already own a Macbook pro. Alas, it has only one headphone ouput, that could be used as input if switched via system preferences. My question would that be enough or do I need an additional sound card?
I'd love to know more mac os x software options for speaker measurements are welcome too.
Thanks!
Old 8th January 2013, 07:03 PM   #2
gk7 is offline gk7  Europe
Originally Posted by Siberia View Post
... it has only one headphone ouput, that could be used as input if switched ...
I would opt for a soundcard then. Most measurement software puts out a
test signal and measures in a defined time window so you will need input
and output. A soundcard with microphone inputs already built in probably
would be suited best.
Maybe its best to have a look at the software documentation first to see
what the requirements are. What do you intend to use ?
Georg
Old 8th January 2013, 07:06 PM   #3
frugal-phile(tm)
planet10's Avatar
Lots of external semi-Pro USB I/O boxes. They will all have mic pre built in. Fuzzmeasure ($$) or REW (free) for measuring
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th January 2013, 07:42 PM   #4
Siberia's Avatar
Alright, got it. I was thinking of Arta (via Crossover) use, as mostly recommended.
Do you think ECM8000 mic with this Specifications | Focusrite would be an overspecified option for a hobyist like me?
Old 8th January 2013, 08:06 PM   #5
frugal-phile(tm)
planet10's Avatar
I haven't played much with Crossover, it does give more sw flexibility. There is also Sun's Virtual Box, VMWare & Parallels. You still have to deal with the typical 3 cliks when one would do WIndoz interface.
ECM8000 is the cheap entry levelmeasure mic. It needs to be calibrated to be useful. The Focusrite is exactly the kind of I/O box i was thinking of. I have 2 Edirols/
dave
Old 8th January 2013, 08:24 PM   #6
Siberia's Avatar
Thank you, Dave! I do use Crossover and it works fine, although not without some minor glitches for ex. while working on PSUD2. ECM8000 (uncalibrated) + Focusrite would be around 260$. It's not very cheap on my planet. Still doable.
Old 13th January 2013, 02:41 PM   #7
Siberia's Avatar
Sorry, one last decision making quesition. Am I doing better with this mic and pre
iSEMcon GmbH together with a borrowed mac with two default/input output jacks?
Measurement mic question sobazz Multi-Way 24 15th January 2011 11:02 AM
'Tube' preamp bad for measurement mic? also Apex mic question morbo Multi-Way 10 23rd March 2005 10:19 AM
Measurement mic confusion... sobazz Equipment & Tools 5 6th February 2004 10:07 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
