Scope not Showing Correct Square Wave - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 25th December 2012, 07:38 AM   #11
Update:
I tried removing the front plate to get access to the rotary switches but it was to no avail. The front rotary plastic switch knobs are held on by bolts which are covered by stupid plastic protectors. I tried to pry one off and nearly broke the front plastic knob. I then tried to destroy it and remove it in chunks but I didn't make much progress in an hour. I guess the only solution is to get the right size drill bit with a round cut-out to remove the plastic bolt protector remnants. As I don't have one now, I cleaned the ac/dc switches and sprayed a ton of evaporating cleaning solution at the rotary switches. I will wait a bit and let you know what happens when I power it up!
2X Com-tech 400, Improved Headphone Amplifier
Old 25th December 2012, 09:21 AM   #12
jan.didden's Avatar
Originally Posted by techbiker View Post
Thanks for the quick replies. The square wave in these pictures was generated by my laptop (audacity) but channel B shows no slanted vertical lines using the CAL square wave on the scope itself. Just horizontal dashes (as i believe it should).
That's the give-away that there is nothing wrong with the scope.
A square wave from a PC with 44.1 sampling can be expected to have non-ideal rise- and fall times; add to that interlinks that are probably not very good on HF and there you go.
As bear noted, check with a short cable from the scope CAL terminal. If that shows sharp squares, the problem is the signal going into the scope and the scope shows the rounded corners truthfully.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 25th December 2012, 06:00 PM   #13
expert in tautology
bear's Avatar
The little blue things - the caps with the indicators - other colors on other knobs - do snap off. However they are brittle as they can get after aging 25+ years and will crack. What you can try is to put a drop of silicone lube on the border/edge of the cap and knob, wait a few hours for it to migrate in. Add a bit of heat from a hair dryer (this softens the plastic a bit), then use a razor knife to go parallel to the surface of the indicator cap at that edge and pry gently... they may snap out... or break.
These caps can be bought new from the mfrs of knobs of this type... or stolen from other gear that has the same knobs.
Under the cap you need a metric thin wall nut driver or a thin long nose pliers to unscrew the nut about a turn - they are collet nuts.
I'd exercise the switches, and hit them with the aforementioned contact lube before trying to replace them... they will likely "come back".
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 27th December 2012, 05:34 AM   #14
Howdy!
Bear, I removed those blue caps without a problem but my collet nuts have thick plastic blocker pieces either glued or molded to them (inside the outer plastic switch knob). The only way I can think of to remove them would involve smashing them and removing them in bits or using heat (but this might damage the outer knobs).
Instead, I used some Fry's branded contact cleaner (completely evaporating) in a large can and dumped about half of it on to the contacts over about a 2 hour period while twirling the knobs. The room was practically flooded with cleaner. I've gotten every amplitude switch down to 20mv clean with 10mv and 5mv still intermittent but adequate for now.
Cleaning the push button switches, then filling them with di-electric grease seems to have fixed the square-wave problem! Hopefully the grease will keep moisture and dust out for now.
If you have a PM3215 and have the same problems as myself, there is a small opening in the back of the faraday cage around the attenuators that can be opened enough to spray contact cleaner through.
Honestly though, if this is a major problem I will consider cutting a hole in the cage somewhere and installing hinges or something for easier access. Removing the front faceplate is an exercise in frustration in my opinion.
Thanks for all of your help!
Old 28th December 2012, 03:52 AM   #15
expert in tautology
bear's Avatar
I have a different but similar Phillips scope... slightly upscale version.
I can't say for sure, since silly stuff has been done, but usually the parts of these scopes comes apart pretty ok... but as long as you have it working, then that's good enough.
Can you post a closeup of the inside of the knobs, so we can see the collet? I'd suggest putting a magnifying glass on the lens, using the closeup setting, and moving the camera to focus with the shutter pushed slightly (that's the focus/light meter position) and then shoot... something is odd that there is anything in there on all the knobs...
_-_-bear
Old 28th December 2012, 06:42 AM   #16
Sure! I'll grab some good shots tomorrow when I get up. It seemed strange to me too since this was not in the manual...
By the way, if I choose to calibrate my scope completely, are there any modern substitutes for a time mark generator and square wave calibration generator? I'm considering buying a new function generator but I hope to find out whether I can acquire all of the requisite test equipment in a calibrated state (i.e., not from 1975). lol
Old 28th December 2012, 08:22 AM   #17
Are there any modern substitutes for a time mark generator and square wave calibration generator?
Sure--just check out the Fluke 9500B...
Seriously: even if you buy a recently calibrated Tek PG506 and TG501, this will be much cheaper than any modern equivalent. Furthermore, IIRC, the basic important calibration procedures for these two units are not particularly difficult.
Samuel
Old 28th December 2012, 01:02 PM   #18
expert in tautology
bear's Avatar
With all due respect to the previous poster, there's absolutely no good reason to "fully calibrate" this scope. Unless it is way off, nothing you can do will really make it stable or accurate enough to use it as a precision measurement instrument. Save your effort, just check that it is close now - the internal time base of the calibrator is good enough to check the timebase accuracy. That can be checked against a decent freq counter. Good enough.
The amplitude (gains) have tweaks for the main and the high sensitivity ranges. It might be worth tweaking those - they tend to be off a bit... but I use a HP AC voltmeter for accurate sinewave testing, or another more modern scope...
The cost of a calibrated Tek or Fluke will exceed the value of that scope by a significant amount - you could buy a higher bandwidth more modern scope or one of the DSP based import scopes for equal or less money, I expect.
_-_-bear
_-_-bear
Old 28th December 2012, 02:14 PM   #19
Elvee is offline Elvee  Belgium
Elvee's Avatar
Quite right and sensible, and anyway an excellent calibrator can be made for very little money:
Start with some 10MHz xtal oscillator (or any similar value, a round number is more convenient) and add a string of frequency dividers (74HC390) down to 10Hz or so.
Add a selector, a buffer (8 operators of an octal HC or AC buffer in //), a precisely adjusted 5V regulator and a string of dividers, see example.
Adjust the supply voltage with a static level, monitoring the first 5V out with a DMM.
The resistors can be selected accurately, also with a DMM.
A 0.1% total accuracy can be reached easily, more than sufficient for a +/-2.5% calibration.
More division ratios can be added if desired (1-2-5 for example)
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 28th December 2012, 06:45 PM   #20
Cool! I suppose that I can build this calibrator to produce the frequencies that I need to calibrate my scope. Also, when it asks for a time marker voltage with a repetition time of 1 us and an amplitude of 80mv p-p, do I just need to convert the repetition time to a frequency for the oscillator?
Thanks very much
By the way, I have attached a picture of the front knobs with the blue tips removed. Notice the gray plastic pieces on top of the collet nuts. I cannot seem to remove these easily without destroying the knobs themselves. Let me know if you need more pictures.
Linn Lingo vs. Dr. Fuß or Square-Wave vs. Sine Wave Oscillator for Motor Control tiefbassuebertr Analogue Source 64 19th September 2016 10:10 AM
Understanding Scope Trace Square Wave Hearinspace Equipment & Tools 5 3rd August 2010 05:23 AM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
Copyright ©1999-2017 diyAudio
