decent soundcard for measuremets - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 22nd December 2012, 05:55 PM   #1
regal is offline regal  United States
Default decent soundcard for measuremets
I had the TOL Asus soundcard and it made good measurements but it couldn't do 44.1, 88.2, or 176.4 so I sold it in haste. I have a buffer setup for attenuating signals before a soundcard ADC.
I have a newer motherboard that was incompatible with my EMU 1616 PCI since the PCI slot isn't part of the H67 chipset (legacy slot.)
Just looking for USB and a quiet noise-floor, nothing too expensive.
Looks like the best bet is an EMU 0202 USB for taking decent measurements with Arta, RMAA, Audiotester, etc. Any other suggestions before I buy it ?
Old 23rd December 2012, 02:56 PM   #2
I believer the E-MU 0202was discontinued. I am quite happy with the E-MU 0204 (USB), except that I had to modify it to have 48V phantom power. E
Old 23rd December 2012, 03:07 PM   #3
the USB 0204 doesn't have a digital output does it?
I found this but the specs on the wolfson adc are poor:
QA01 USB to SPDIF Digital Sound Card Analog to SPDIF Coaxial Optical Converter | eBay
Old 29th January 2013, 11:37 PM   #4
Telstar is offline Telstar  Italy
Did you consider TI pcm4222 evaluation board and just your motherboard spdif input?
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 30th January 2013, 03:58 AM   #5
Frex is offline Frex  France
Hello,
For good audio ADC/DAC low cost sound card, you can look the ESI Juli@ that exist in
PCI or PCIe version (internal only).
All I/O (analog and digital) support 24 bits 192kHz resolution.Very good driver and much more stable
than EMU hardware.
Regards.
Frex
Old 30th January 2013, 10:14 AM   #6
I need USB.
Old 30th January 2013, 10:45 AM   #7
Originally Posted by Telstar View Post
I need USB.
I agree, not many motherboards have a 24/192 spdif input, at least one I would trust for measurements, with these new inexpensive asynch usb interfaces like CM6331 you would think someone would throw a good adc on one.
Old 30th January 2013, 11:27 AM   #8
In other thread, someone suggested the minidsp usbstreamer + some ADC that outputs i2s (such as the pcm4222) - it would be a nice solution, in one box, but I have no idea of the HF performance of this converter.
BTW I dont think jitter matters when we just want to measure a FFT.
Old 30th January 2013, 11:53 AM   #9
Well if you believe in that multi thousand dollar ADC where reviewers are running J-test etc, then there is some group of folks who believe it does. I think the technology is there to match that device for a fraction of the cost.
Old 30th January 2013, 12:04 PM   #10
I believe jitter influences the sound, but not the harmonic spectra. Am I right or wrong?
looking for a decent enclosure dannycelluk Chip Amps 4 5th January 2010 09:38 PM
R2904/700000 measuremets file...... ermes Multi-Way 6 2nd August 2005 08:10 PM
Is This a Decent Setup?? TheNoodPoopler Car Audio 11 21st May 2004 12:50 AM
decent pc soundcard with multiple outputs? zag0r Digital Source 6 10th May 2004 04:00 PM
Need a decent kit Konnan101 Solid State 4 5th February 2004 06:02 PM
Copyright 1999-2017 diyAudio
