decent soundcard for measuremets - Page 5 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 21st February 2013, 10:43 AM   #41
regal is offline regal  United States
Originally Posted by tvrgeek View Post
. I am beginning to think semi-pro recording equipment makers are all trash and that is better than their products. What the heck out there actually works?
The TOL Asus PCIE sound cards work fairly well even with new computers they do 24/192 but can't handle 176.4khz.
Old 21st February 2013, 07:31 PM   #42
tvrgeek is offline tvrgeek  United States
Well we can see what kind of company M-Audio is. My question on loop back and clipping cross talk was removed from their forum.
Ordering a Focusrite tonight. Bodzio suggests the Firewire version for SoundEasy but besides the money for features I don't need, it comes with this fancy mixer software like the emu did which was a real pain. So, I may try the 2i2 as it is absolutely simple, and if I need the Pro 14 Firewire, at least I'll have a USB for portable audio testing that works. The M-Audio FastTrack has too much in to out mix.
Fancy sound cards have a problem in long cables and I would need a separate mic preamp. They eliminate the USB/Firewire problem though. Too bad the emu was such a piece of junk, as it was a PCI card with external acquisition head unit.
The vendor I was talking too thinks Focusrite is stand up. He also implied the problem is in the drivers and emu and M have really poor drivers. They all use the same chips.
Old 21st February 2013, 07:41 PM   #43
Originally Posted by Telstar View Post
I'm looking only for a good AD and decent drivers to run ARTA or Spectraplus as a spectrum analyser, nothing else, I prefer to use an external generator (battery powered).
On a different computer I have a 1616m pci and I didnt have any issue with its drivers, but I never tried the AD.
"96 KHz, 24-bit conversion" - wonder where the HF noise starts :/
ARTA, HOLM and others big advantage is they use the MLS method for the spectrum analyzer that allows you to gate the measurement. Even for LF tests where I use TrueRta, I use "Quick Sweep" so as not to aggravate the room too much. Can't do that with an external generator. SoundEasy uses a reference probe concept that should zero out most of the test system error. I think HOLM does too, but I have not had time to play with it. I keep an external HP generator around as with it and RtueRTA, it is easy to investigate modes in a room and things that rattle. No good for speaker design work. So, it depends on what you are using it for.
The 1616m issue depended on the host. I had on-board video. The problem was the emu kept trying to write to it. Where your drivers are installed may have made it a non-issue. Just playing back a CD would crash. The person who bought it had a Mac.
Where does the noise start? Looking at tweeters, the 96K sample rate is fine for seeing the breakup modes in the low 20's. I wanted the higher rate as I also work on amps and wished to see distortion into the 100K range.
Old 21st February 2013, 07:49 PM   #44
soundchaser001's Avatar
Default Need a USB card for ARTA...Maybe Tascam?
I was looking at the 0404 and 0204 from EMU but had heard that there was no support for WIN7 (Beta drivers only).
I was going to look at the Tascam US series (US322, US200 etc). Up until now I had used an M-Audio Audiophhile 192 but I am switching to a laptop based system for everything (measurements, CAD, reading etc) and a USB or Firewire interface is required.
Have ordered the laptop but haven't picked a sound interface yet.
Matt
Old 21st February 2013, 08:05 PM   #45
PGDO is offline PGDO  Netherlands
Matt
I used the EMU 0404 with W7 x64 and Arta without any problems, switching to the EMU 1616 now.
Peter
Old 21st February 2013, 08:11 PM   #46
Peter
Thanks; that's good to know. These are still available.
Old 21st February 2013, 08:42 PM   #47
Telstar is offline Telstar  Italy
yes usually soundcards beta drivers work fine, IME.
tvrgeek note that i need to do only THD and FFT measurements of electronics, not room/speaker measurements.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 21st February 2013, 08:56 PM   #48
Ordered the 2i2. Alan at SW says the improvements in the drivers in the last year for USB-2 have made them more stable and faster than Firewire. I have a Profire 610 available now, cheap. And a FastTrack.
Telstar,
I can see the prospect of lower noise with battery power. Getting the power line noise out of a test bench can be really hard. I used just plain TrueRta for setting tube bias with my old HP generator. It is clean enough even on line power. That was why I wanted the 192K acquisition. For really decent measurements though, you may not get there with a sound card. Think good old HP notch filter setup off e-bay.
Old 12th April 2013, 12:41 PM   #49
Correct me if I'm wrong but, as far as i know there isn't any usb chip that does 24bit let alone 192Khz, it's all upsampled.
There are some firewire based systems that can go up to 24bit but these are very expensive, your best option is a PCI-e one.
Adir.
Old 12th April 2013, 02:55 PM   #50
Peter
I have some issues with stability with 0404 and W7 X64.
Not that it prevents me from using the card, but I would carefully consider using this producer in the future as they seems to have dropped all support.
listen! Can you hear that ...
looking for a decent enclosure dannycelluk Chip Amps 4 5th January 2010 09:38 PM
R2904/700000 measuremets file...... ermes Multi-Way 6 2nd August 2005 08:10 PM
Is This a Decent Setup?? TheNoodPoopler Car Audio 11 21st May 2004 12:50 AM
decent pc soundcard with multiple outputs? zag0r Digital Source 6 10th May 2004 04:00 PM
Need a decent kit Konnan101 Solid State 4 5th February 2004 06:02 PM
Copyright 1999-2017 diyAudio
