How to enter service screen in Tek 2467? - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 1st December 2012, 03:04 PM   #1
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Default How to enter service screen in Tek 2467?
There is a screen in Tek 2467 which allows adjusting inactivity CRT shutdown time, it displays the number of hours, on/off cycles, etc. How to enter it? I forgot Thank you
To enter self-test screen push and hold down both the delta V and delta T buttons then push Slope button. Push MODE UP to run test after test or push COUPLING UP to run all tests.
Old 2nd December 2012, 07:19 AM   #2
Can't help directly, but if you don't get the answer here you should here:
TekScopes : All about classic Tektronix CRT o'scopes
Samuel
Old 7th December 2012, 10:10 PM   #3
Loudthud's Avatar
Press and hold delta V and delta T buttons at the same time, then press Trigger Slope while holding them. The upper or lower Trigger MODE allow you to go between screens. The upper Trigger COUPLING button allows you to execute the test or exercise on the screen. Press the lower Trigger COUPLING button to exit.
Old 7th December 2012, 11:00 PM   #4
dimitri's Avatar
Thank you Loudthud, but this combination will lead you to self-test screen (see my question)
Old 8th December 2012, 02:12 AM   #5
Loudthud's Avatar
I can't figure out how to make this editor work properly so I'm attaching a text file
Old 11th December 2012, 04:56 PM   #6
dimitri's Avatar
You are , thank you so much!
You must enter a title / subject! tomtt The Lounge 4 11th May 2010 12:06 PM
PSUD Help Needed: What value do I enter for current? bluegti Tubes / Valves 8 25th January 2010 12:30 AM
Help! Looking for a Tek 2225 Service Manual or schematics?? wildswan Equipment & Tools 2 9th November 2009 12:18 PM
Someone with LEAP please enter ocaukrell Subwoofers 6 17th August 2006 02:42 AM
Looking to enter the Audio world. Need help ibanezcollector Introductions 4 27th December 2005 04:49 AM
Copyright ©1999-2017 diyAudio
