Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 27th November 2012, 01:20 PM   #1
Default Power supply and oscilloscope problem
I have a power supply with an AC output (0-22V, 4A). I want to use this output to simulate the secondary of a power transformer, not having to worry about circuit protection for now.
I wanted to use my oscilloscope (a Tektronix analog scope) to look at the effect of load variation from my regulation circuit.
I have the following problem: when I connect the tip of the oscillloscope probe, then the common, the voltage of the power supply drops significantly (as can be seen on the power supply display) and after 5 seconds the circuit breaker of the unit goes off. I made several test, I even succeeded at blowing the 2 amp fuse of the unit.
After some tests, I also noticed that using the DC output has the same effect. I switched probes, same results. I also verified with a multimeter (battery powered) there is no voltage drop between the oscilloscope and the unit grounds.
When I use my PC oscilloscope, this does not happen.
Does anybody have an idea of what could be wrong here? I never had any problem with the scope before.
Old 27th November 2012, 03:09 PM   #2
DUG is offline DUG  Canada
Here is my guess:
The analog scope ground is connected to the AC safety ground and your power supply is the equivalent of a btl output. You are actually shorting one of the outputs to ground.
Solution(s):
If your scope has two inputs then connect the two probes to the two AC feeds and use the A-B function to view the difference.
OR build a differential to SE opamp cct that divides by 10
Always watch out for smoke.
Doug We are all learning...we can all help
Old 27th November 2012, 04:09 PM   #3
Do you mean that one of the AC outputs is directly connected to the ground? Could reversing the outputs fix the problem?
I could check to see which output has zero voltage with ground.
And thanks for the smoke warning
Old 27th November 2012, 04:19 PM   #4
maybe
just a guess...I'm not there
Old 27th November 2012, 04:28 PM   #5
Ok, I'll just try that. Thanks for the info, it never came to my mind that one of the output could be gronded.
Old 27th November 2012, 10:43 PM   #6
DF96 is offline DF96  England
Unless told the contrary you should always assume that a power supply output, whether AC or DC, has a ground reference. In some cases this may be absent or switchable.
Old 28th November 2012, 12:41 PM   #7
Thaks guys for your replies.
LeCroy 9354AM oscilloscope power supply Craig405 Parts 3 19th December 2011 07:34 AM
power supply problem denmobfast Power Supplies 2 11th August 2011 12:30 PM
Power Supply problem Landoctor Chip Amps 3 8th September 2007 07:50 PM
Power supply problem argonrepublic Parts 0 23rd January 2006 05:35 AM
Power supply problem (or something) ir Chip Amps 4 23rd August 2003 08:44 AM
Copyright ©1999-2013 diyAudio
