| Equipment & Tools From test equipment to hand tools |
I want to add an active probe to my test gears. Downloaded D. Feucht "Buffer Amplifier Design" (http://www.analogzone.com/col_01302004.pdf). Is the JFET circuit shown in this article adequate? LTspice AC analysis shows f_3dB at about 225 MHz. At 100 MHz, gain is about -1 dB.
#2 |
How should we know if a certain circuit is adequate if we don't know your requirements? Key parameters are:
* Input resistance and capacitance * attenuation (perhaps even gain?) * bandwidth * AC coupling * input signal range * offset control Some links: http://elektrotanya.com/files/forum/2009/10/e04a036.pdf http://welecw2000a.sourceforge.net/d...mit_OPA659.pdf (German only) http://igor.chudov.com/manuals/Tektr...obe-Manual.pdf BTW, Tektronix P6201 are now getting so cheap that, besides the fun and learning experience, there's probably few reasons to DIY. Samuel |
#3 |
I need the probe be able to measure down to 10 Hz. Upper frequency cut-off should be at least 100 MHz. 500 MHz would be better to match with the scope BW.
Input resistance 1 MOhm, capacitance less than or equal to 1 pF. |
#4 |
That low input C at this bandwidth is surely pretty demanding. Your best bet is probably a 10x design. Layout will be very critical--there's quickly a few 100 fF sneaking in.
At low frequencies you can use bootstrapping (see http://www.ti.com/lit/an/snoa620/snoa620.pdf, page2), but I'm not sure if this can be extended to such high bandwidths using ordinary PCB level techniques. Also see Pease, Troubleshooting Analog Circuits, page 16/figure 2.3 (available at Google Books). Samuel |
| Homebrew phase plugs | loninappleton | Full Range | 48 | 10th August 2009 04:25 PM |
| Homebrew Toroid O/P Tranny | boiss | Tubes / Valves | 10 | 9th May 2007 04:07 AM |
| Homebrew Spectrum Analyzer | Duo | Everything Else | 44 | 14th March 2007 08:44 PM |
| Homebrew poweramp... | koolscooby | Solid State | 13 | 27th December 2003 02:10 PM |
| Help with homebrew mic preamp please!!! | mwmitchell | Tubes / Valves | 6 | 15th September 2002 06:48 AM |
