Drill chuck for component leads - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 31st October 2012, 04:10 PM   #1
indianajo's Avatar
Default Drill chuck for component leads
I decided to add two diodes to a PWB yesterday to make up for a possibly off brand op amp. Costs $10 shipping to get the $.33 JRC4558D part and my pension doesn't come in for days. It took me over 2 hours with needed rests to drill 4 #61 holes with a pin vise. #61 drills won't fit my 1/4" hand drill, or my precious US made 3/8" milwaukee "holeshooter". The pin vise has threads on the back for the swivel pad and I don't want to put it in the 3/8" chuck and mess them up.
Is there a $20 solution if I want to a lot of these holes? Glass reinforced board is a *****, My next project involves 36 telephone relays with short leads on a very thin board, probably has to be glass reinforced. I know where to buy the carbide drills (mcmaster.com) but where to buy a tiny chuck for my $5 B&D 1/4" drill? I've been using #48 drills and a hand crank stanley yankee drill I found for $2 at the flea market, on fiberboard, but #61 is more correct on a packed PWB. Hand cranking wiggles the drill shaft and would probably break carbide, anyway. #61 drills won't fit the Yankee drill chuck, either.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 31st October 2012, 05:30 PM   #2
marce is offline marce  United Kingdom
I use a cheep version of the dremmel, bought from Aldi in the UK for about 20 quid, I would imagine you can get similar in the USA. The high RPM helps with the smaller bits.
Old 31st October 2012, 07:13 PM   #3
try these
Gyros Adaptor Chucks - Works with Dremel
Old 31st October 2012, 11:02 PM   #4
indianajo's Avatar
Great, gyros adapter chucks are just the thing. Under $20 too!
Old 8th November 2012, 05:28 PM   #5
I`ve used a short length of appropriate size PVC or PTFE sleeving to bush a small drill from time to time.
Hand Tool to Form Component Leads ? johnferrier Equipment & Tools 6 14th August 2010 02:44 PM
Steel Leads and Tinned Copper Leads impsick Parts 0 19th April 2009 10:01 AM
Broken drill bit in chuck gmphadte Equipment & Tools 14 14th September 2007 04:19 AM
To drill or not to drill? (a VPI turntable) m.parigi Analogue Source 5 6th January 2006 02:32 AM
should I chuck my P-mount TT? leadbelly Analogue Source 10 15th March 2003 10:22 PM
Copyright 1999-2017 diyAudio
