| Equipment & Tools From test equipment to hand tools |
#41 |
It shouldn't change, as the only mod has been re-routing the cables, not any change in components.
Regarding pots, I have the same problems. Even after some years of intensive use, output volume pot is starting to crack and make funny noises when turned up/down. The main downside I can see is how to fit a physically bigger pot in that cramped space.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#42 |
Just bought two units on Kijiji and modded them. Worked great. Thanks sidiy and everyone else who contributed.
In order: Left 1 Before Left 1 After left 2 Before Left 2 After Thanks again Matt Last edited by soundchaser001; 17th April 2013 at 12:55 AM. |
#43 |
What mods did you do? The one posted above by sidy?
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#44 |
#45 |
This looks great... clean with no residual freqs all over the place. Just ordered one to modify.
Thx-RNMarsh |
#46 |
Has there been any similar products which use the better AK5388? That one is being sold for about $10 in singles at DigiKey so I wonder if it is inside anything we would want to use/modify.
Thx-RNMarsh |
#47 |
#48 |
Has anyone tried paralleling ADC in some way for improved performance?
Seems this could be done with multiple ADC IC's or with multiple channel products. Thx-RNMarsh |
#49 |
I just did the sidiy rewiring mod. Thx a lot. -Richard
| E-MU 0404 USB Modification? | lumanauw | Digital Line Level | 105 | Today 12:18 PM |
| E-mu 0404 problem | tonyptony | Digital Line Level | 2 | 25th August 2012 01:00 AM |
| Opinions on pc/mobo "onboard spdif to Ian's FIFO kit" or "USB to WaveIO" to I2s? | edbk | PC Based | 0 | 1st May 2012 02:40 PM |
| FS: E-mu 0404 USB external sound card | Jack Hidley | Swap Meet | 2 | 14th March 2008 01:00 AM |
