| Equipment & Tools From test equipment to hand tools |
Hi
I am owner of 30yr old distortion meter and would like to switch to something new. What is your setup? What do you use? I know that nowadays distortion analysers are uber expensive, so I suppose one have to use some modern setup ( e.g. better sound card, like 192KHz/24bit ASUS Xonar D1). Is Cordell's Distortion Magnifier worth trying? CordellAudio.com - The Distortion Magnifier Do you use it? Regards michael |
#2 |
Yes, the Cordell unit is very worth having.
A good 24/192 sound card with an inexpensive analog interface (Pete Millett's is available as a kit if you don't want to design/build one yourself) gives you remarkably good distortion measurement capability. I'm using AudioTester and Arta software, an M-Audio 192 PCI card, and both a home-made interface and Pete's unit.
If there's a sucker born every minute, where do the rest of them come from? |
#3 | |
Do you mean this one? Soundcard Interface I like it! About Cordell's DM -kit is quite expensive. I'd love to see how it is built, but I have no way of taking a look into "Linear Audio - Volume 0" article. I am trying to work things by myself -it is cheaper this way. mike |
#4 |
That's the one. I changed the input impedance to 1M so I could use scope probes with it (10x often comes in handy). My own interface has BUF03 buffers for higher drive current, but also suffers from higher noise.
I have no problem measuring distortion components to better than -150dB. Coincidentally, the editor/publisher of Linear Audio is sitting across the table from me at the moment and confirms that Volume 0 is still available.
| Measurment question | imaginarytime | Multi-Way | 2 | 10th October 2012 11:26 AM |
| Power amp distortion for modern amps | hpupo | Tubes / Valves | 5 | 28th December 2011 01:23 PM |
| Loudspeaker Design and Measurment Software | harvylogan | Equipment & Tools | 2 | 19th November 2011 05:47 PM |
| Free to good home..HP 302a distortion analyzer-needs work | boywonder | Swap Meet | 8 | 12th March 2010 01:58 PM |
| impedence measurment questions | tom1356 | Multi-Way | 1 | 19th March 2004 06:32 PM |
