Isolation Transformer - AC Plug question - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 13th October 2012, 12:50 AM   #11
kevinkr's Avatar
Originally Posted by DF96 View Post
Those IEC power input/output sockets are perfectly normal and standard in Europe. The cables are widely available over here.
We're not exactly an IEC backwater over here either..
They're quite readily available from most electronic component suppliers, and at hamfests.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th October 2012, 11:33 AM   #12
DF96 is offline DF96  England
Sorry, I was not certain how widespread they are elsewhere. Clearly the OP thought they were exotic. The fact that they are widely used for computers should have alerted me.
Old 16th October 2012, 11:35 PM   #13
rize is offline rize  United States
Thank you. I found the pig-tail IEC male/female adapters on eBay.
Old 17th October 2012, 12:45 AM   #14
I understand an iso traf connects two separate transformers magnetically. In this particular Toroid traf, the isolated side's neutral is not grounded. Let's assume by mistake it was. For the example of a 2-prong classic radio, plugged into the Toroid iso-traf, what is the risk for a DIY'er who has taken precations of not grounding himself?
Old 17th October 2012, 12:34 PM   #15
'connects two windings magnetically' not 'two transfomers'
If the output from an isolation transformer is grounded on one side then connected to an AC/DC radio then you have largely undone the benefit of isolation unless you can guarantee that you have grounded the 'chassis' side. The only benefit you get is a higher impedance supply so possibly a bit less 'shock' current.
Old 17th October 2012, 01:36 PM   #16
For an isolation transformer, the secondary/output must NOT be connected to Neutral/Earth/PE.
The output MUST float.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th October 2012, 11:22 PM   #17
Default Toroid iso-traf upgrade
Originally Posted by kevinkr View Post
I've got a 600VA and a 1kVA made by Toroid Corp of Maryland, the maker of your unit. The company is very much still in business, in fact we have a bunch of these at work. (I work in medical electronics.) Note that the output is floating and interestingly I found that the overall hum level in my system decreased very slightly.
Thanks... when I read this I gathered the courage to violate Naim's rules - i.e., not to plug a Naim unit into any noise supression unit.
I plugged my integrated amp (Naim Nait-1) into the Toroid iso-traf, the noise drop was significant. There was more music and information - I had to turn it louder. Naim's line-stages have too much noise. Nait-1 is 80's technology but one shoe-size box can surprise you. When it came out it sold for $400-500 but now you're lucky if you can get one on eBay for less than $800. Naim will emphasize selling their customers expensive external PSU upgrades - clever marketing that have made them millions.
The difference I heard with the Toroid iso-traf (much cheaper than a Naim PSU) was at least as good as adding an external Naim PSU which sells used/new between $700-1500. Nait-1 is not upgradable by a separate Naim PSU but more modern Naim pre-amps and cd players are. With Nait-1, it's possible to upgrade the internal monolithic power regulation circuit with a super-regulator. Naim recommends against noise-supression, filters, etc claiming it will degrade or change the sound. Well with Toroid iso-traf plugged in, Naim's unmistakable PRAT is still there and grooving better than ever. To my ears it sounds as good if not better as adding one of their Hi-Caps (external PSU) - maybe it's the psycho-acoustic effect of paying less and getting something in return .
Newbie Question - Power Transformer vs Isolation Transformer SparkyPete Tubes / Valves 10 2nd November 2012 07:13 PM
Isolation Transformer Question Skuker Tubes / Valves 8 30th November 2009 08:28 PM
Isolation Transformer Question Captn Dave Tubes / Valves 6 28th April 2009 04:30 PM
Question about how to wire an Isolation Transformer gpapag Everything Else 91 27th April 2009 05:48 PM
Isolation Transformer question Jack Torrance Power Supplies 7 2nd January 2007 09:37 AM
Copyright 1999-2017 diyAudio
