Faulty Dayton WT3... - Page 6 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 2nd September 2013, 03:36 PM   #51
Pano is offline Pano  United States
Pano's Avatar
The second entry was just a happy guess. You can unprotect the sheet with the password wt2 if you want to change anything.
You want 10 trials of the same values?
Old 2nd September 2013, 03:55 PM   #52
10 trials with one emulator. I found that there was not good repeatability with the WT3 I used. It also never got close to the correct Qts.
Old 2nd September 2013, 03:57 PM   #53
Pano's Avatar
Will do.
Old 3rd September 2013, 01:31 AM   #54
Pano's Avatar
Default WT3 tests
Here are 3 trials of 10 sweeps on the same driver. Software shut down and restarted between run 2 and 3.
Qts=
0.6457
0.6457
0.6456
0.6459
0.6458
0.6528
0.6459
0.6456
0.6452
0.6456
0.6573
0.6572
0.6569
0.6568
0.6570
0.6566
0.6569
0.6573
0.6570
0.6575
0.6569
0.6566
0.6571
0.6567
0.6571
0.6567
0.6566
0.6565
0.6569
0.6567
I'll build an emulator and try that.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 6th September 2013, 12:58 AM   #55
Pano's Avatar
Strange, I see that my emulator post from Monday didn't make it thru. A glitch.
Anyhow, with a big inductor of about 11.5mH and a 10000 uF cap I got results that were somewhat near the mark. Trying with a smaller inductor, like 6 mH, I could not get numbers anywhere near what they should be by formula. So maybe the WT3 doesn't work that way?
Old 6th September 2013, 01:09 AM   #56
For the 11.5 mH inductor what is the resistance of the inductor?
For the 6 mH inductor what is the resistance of the inductor?
Old 6th September 2013, 01:12 AM   #57
Pano's Avatar
0.4R and 0.25R, I think. Will go to the lab and check.
Old 6th September 2013, 01:28 AM   #58
Pano's Avatar
More info:
Inductors were 4.1 mH DCR 0.29 ohms and 11.92 mH DCR 0.42 ohms
Caps of 10000 uF and 15000 uF were used, but I don't have away to measure values that high.
Old 6th September 2013, 01:37 AM   #59
Originally Posted by Pano View Post
More info:
Add 5% to the capacitor and run the calculation. Subtract 5% from the capacitor and run the calculation. That should bracket the measurement.
Report the calculated Fs and Qt bracketed values and what results you obtained for your WT3. That will be a starting point for the discussion. There is an easy experiment once you have this base line reported.
Old 6th September 2013, 02:03 AM   #60
frugal-phile(tm)
planet10's Avatar
Originally Posted by gornir View Post
I'm sure the WT2 device is equally good or better than the WT3
The Smith & Larson WT2 is WAY better than the WT3 (at least for T/S, i don't use it for anything else).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Dayton Audio WT3 accuracy issues TheBaronGroog Software Tools 3 15th August 2012 10:13 PM
Dayton WT3 Speaker Tester Loren42 Multi-Way 37 9th November 2011 03:19 PM
Dayton WT3 testing tweeters mitchyz250f Equipment & Tools 2 28th August 2011 09:25 AM
denom pma250 amp faulty,but no faulty parts found please help homertooties Solid State 1 7th December 2008 03:58 PM
Dayton WT3 Woofer Tester available next month! BHTX Multi-Way 14 30th October 2007 07:32 PM
Copyright 1999-2017 diyAudio
