| Equipment & Tools From test equipment to hand tools |
#31 |
expert in tautology
Ahhh, I see.
The main diff is lower noise floor in the analyzer, and balanced input... plus the onboard filter switches... ...which means different boards. And, although I have not checked the manuals, I would be somewhat surprised if the E model used the same components as the B, but I suppose it is possible... older ICs get hard to source for new production. _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#32 |
expert in tautology
Fwiw, and fyi, and pending any time to *actually do anything* I am acquiring some additional *boards* for the 8903A presently. Assuming I can get those that are doing the right stuff functional, then it may be possible to socket the ICs, look at the noise sources, improve the local regulation (hey there may be a real use for SMT?
) and try some newer ultra low distortion opamps in the holes...yikes! another big project... phew. (yeah, but I could be the 8903A hero?) _-_-bear
#34 |
expert in tautology
Looks like I have to print the entire manual to see what is going on, trying to look at this as an on screen pdf is fruitless.
![]() _-_-bear
#35 |
How is the improvement of the 8903A coming along? Any progress?
Cheers |
#36 |
expert in tautology
Improvement? Ha! I have to get the first one I got off epay working!!
Thought I had it when I fixed an intermittent in the power supply - not! I got one for parts cheap too... no time. ![]() _-_-bear
#37 |
I just got mine from fedex this am and although it is an "A", i also got the K18 upgrade option from Tucker as well so it really is a "B" in an "A" chassis. Now I have a new input board, not that there was anything wrong with the original, but the new one upgrades the "A" to the "B" with differential inputs. So I got the "A" in great condition, the upgrade kit, and all three brand new HP bound manuals for 400.00 delivered.
Merry Christmas and Happy New Year to me!!!! Cheers |
#38 | ||
And does any or all of this stuff measure IM distortion? |
#39 |
expert in tautology
There are some threads on soundcards here... I need a new one myself.
The better new ones no only do 24bit/192kHz. but they do it nicely with low residual noise and meet the max spec. But honestly even an average modern 24/192 card is probably going to be pretty good unless ur getting really into some cutting edge low distortion designs... So you take ur signal, be it from the analyzer output (it has one) or direct from the DUT, and build a "signal conditioning" box so you don't fry the input of your soundcard (limited voltage input range) and then run a FFT type software to get a graph of the amplitude vs. frequency, that shows your fundamental and all the harmonics. IM is two tone. Some analyzers come with two tone testing. I personally do not know if the 339A or similar is really terribly useful for this. However, with a Cordell Distortion Magnifier box, it well could be pretty darn good. (that is documented either here and/or online) Crazy stuff...
| HP 3560A Portable Audio I have an HP 3560A 2 channel portable FFT analyzeFFT Analyzer | phaselag | Swap Meet | 0 | 23rd November 2010 11:37 PM |
| Differences between HP 8903A and HP 8903B | cl84 | Equipment & Tools | 2 | 16th June 2010 07:34 PM |
| For Sale: HP 8903A Audio Analyzer | tomchr | Swap Meet | 11 | 24th January 2010 08:33 AM |
| HP 8050A audio analyzer | discovery2008 | Parts | 7 | 20th June 2008 04:01 PM |
| F.S: HP 339A Distortion Analyzer | Cobra2 | Swap Meet | 0 | 8th December 2005 11:17 PM |
