600V bench variable supply to test transmitting valves - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 13th September 2012, 06:45 PM   #11
kevinkr's Avatar
Need to drive grid quite negative relative to cathode to fully cut off.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th September 2012, 07:42 PM   #12
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
Send a message via Skype™ to v4lve lover
I didn't consider the fact that you can run out of voltage headroom for low voltages
You might be able to fully cut off whit a negative voltage of say, 100 volts. But it will complicate matters as you will have to find a way to Turn on a transistor that is below ground
and you will need to find a transistor that can operate at High voltages i remember there are some TV darlingtons that could be up to the task..
v4lve
Old 14th September 2012, 02:51 AM   #13
astouffer's Avatar
Combine the opamp idea with a zero bias tube like an 811A. Handles 45 watts continuous and 65 intermittent.
Old 14th September 2012, 03:23 AM   #14
jackinnj's Avatar
Take a look at the Depletion MOSFETs like the DN2540 to limit current at HV.
Old 14th September 2012, 04:54 AM   #15
HollowState's Avatar
All you guys have lost track of the original post and problem. When testing transmitting and large power tubes, especially of unknown quality, they can and do flash or arc sometimes for various reasons. Transistors, opamps or any solid state componets will not tolerate this. This was mogliaa's original problem. Tubes are very forgiving, transistors are not. They will not serve well in this application. One may think they are somewhat isolated by the series pass tube itself, but that is a bad assumption. In this particular instance sand should be avoided.
Mogliaa,
I strongly recommend not bothering with a regulated HV supply to test a transmitting tube. It just isn't necessary if you monitor and adjust levels as you test. Designing a wide range DC regulated tube supply is not a simple task for most of us unless one is a seasoned engineer. I'm not, but can tell you that what you originally proposed will not serve you well. While you may get some voltage adjustment, you will not go to zero. Like Kevin said you will need a negative voltage source well below common to fully cut off the pass tube.
Also, to achieve regulation, you will need an error amplifier stage that is referenced to a stable voltage. Passive feedback componets will not provide the necessary control. A high gain feedback stage, either single ended or differential, can be used. I don't like zeners as a reference because they drift as they heat. I prefer gaseous diode reference tubes like the 5651, 0G3 or the more common 0D3s and etc.
You asked about connecting the voltage control to the variac in the transformer primary. Yes, the voltage adjust potentiometer should be ganged with the variac. You will need a dedicated plate transformer for this. This will allow you to use a common series pass tube like the 6336, 6C33C or a pair of 6080s to supply 100 mA and not exceed the max plate/cathode level of around 200 volts.
I use a simple LC filter in my plate supply. But I do this for a specific reason, and I'm not regulating. I didn't necessarily mean for you to use this. I think a good way for you to go if you must regulate is to copy an existing circuit from a commercial power supply. Perhaps from a piece of HP equipment or many others.
Victor
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 14th September 2012, 05:18 AM   #16
kevinkr's Avatar
Any good surplus electro-phoresis supply should handle faulty tubes with aplomb.. I used an Isco 494 picked up cheaply on eBay for precisely this reason. (all solid state) Programmable voltage, current and power clamping - with extremely effective protection against load faults including gas discharge, and random arcing. Scary to watch but supply was unfazed by it. There may be equivalent surplus ones available cheaply in the EU.. Otherwise the variac based supply seems a good idea - no off the cuff design with solid state devices is likely to survive this level of abuse.
Old 14th September 2012, 06:00 AM   #17
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by mogliaa View Post
So, question here is: can the GU-50 withstand 600V in triode mode or do I need to look out for options?
Yes, if you don't ask it to dissipate more than 40W constantly, or more than 100W during couple of seconds.
The Devil is not so terrible as his math model is!
Old 14th September 2012, 07:26 AM   #18
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Thanks all for suggestions. As Victor pointed out, I've tried sand there and without a more elaborated circuit, there is no chance it will survive. Also, don't have the time (and patience) now to build many versions of Mosfets regulators and refine the circuit until it can survive a short at these voltage levels.
@Anatoliy: I tested 814 in this mode and survived operating in triode mode above max g2 voltage stated for tetrode mode. I was suspecting that the sturdy GU-50 should be able to cope with this, so great news!
A Variac will probably be the best option here. In the meantime, without adding any additional transformers I can get away with it with the GU-50 in triode mode. I may get an output swing between 85V and 510V @75mA to stay within the GU-50 Pd limits (i.e. 40W in continuous operation). I have everything to fit the valve here in and with a bunch of additional passive components I have this bench supply up and running. Yes, it won't go down 85V, but generally most of the tests I do in the bench are above 100V. It won't allow me to bring any circuit slowly from 0V, I know.
I will need to fit an additional transformer and rectifier to provide a negative 100V. In this case I will be able to provide 0 to 530V easily. I don't think I can use the filament winding for this supply as it has to be referenced to cathode.
Probably what I should do next is to buy a variac for this supply
thanks
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 14th September 2012, 12:16 PM   #19
awsome idea. and if you take +-18v rails you could Tie the transistor to the negative rail and pull the grid below common. A 811A will likely cut off pretty good. @600v But it might pull grid current at higher output voltages.
Ive heard chinese 811A's have trouble going into full cutoff could this be an issue ?
V4lve
Old 14th September 2012, 01:31 PM   #20
Tubelab_com's Avatar
Transistors, opamps or any solid state componets will not tolerate this.....In this particular instance sand should be avoided.
I believed this too......until I stumbled across these mosfets on the clearance page at Allied Electronics a couple of years ago. With a BIG (250 watt) 15 ohm resistor in the drain lead they will not blow into a direct short with 600 volts of supply. Of course they will be over dissipated in short order so a foldback circuit or a fuse is needed. For those who don't want to look through the data sheet, the important numbers are 600 volts, 600 WATTS, 43 AMPS of continuous drain current and 172 amps pulsed. They were clearance priced at $5 each when I got some. I don't know if they are still available. I haven't blown one yet.
I made a simple power supply using a large variac feeding a reverse wired 480VAC (2 X 240) to 120 VAC industrial control transformer rated at 1 KVA. There was a solid state FWB on each 240 VAC secondary making two 0-310 VDC variable supplies that could be wired in series or parallel. A smaller 120 VAC to 24 VAC industrial transformer with a small variac provided variable heater power. I used this for years, but there was no current limiting and several experiments ended in smoking or exploded parts.
I tried several post regulators that usually blew up to protect my experiment. That includes sweep tube pass devices. A huge current spike created by a momentary short takes out the metal link inside the tube that connects the cathode to the base pin. The Fuji fet survivied. A dead short across the output at maximum voltage would trip the bench breaker before blowing the fet (about 2 seconds). 60 amp peak currents will stil fry parts. That power supply was large and heavy, nearly 100 pounds. It has been dismantled.
I got a HP 0 to 600 volt 0 to 1.5 amp supply for big amp experiments. I am using that today, but it's current limiter is too slow to save parts. In fact this power supply has created some serious parts explosions.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Bench test equipment, What's yours? TheGimp Equipment & Tools 39 29th September 2012 03:24 AM
Bench test KEEBIE Car Audio 4 1st November 2006 04:11 AM
Speaker Bench Test evilorange Multi-Way 9 13th October 2005 03:30 PM
What Test Equipment Do You Have On Your Bench?? ultra-lo-fi Everything Else 56 14th June 2005 02:47 PM
845 or 813 valves at 600V? James D. Tubes / Valves 16 20th March 2003 02:58 PM
Copyright ©1999-2017 diyAudio
