cheap isolation transformer: will this work? - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 10th September 2012, 03:22 AM   #1
bullpeters's Avatar
Default cheap isolation transformer: will this work?
Hi
Would this work as the basis for an isolation transformer? To go before my Variac. Its for sale on a popular online auction site but i think if i just post the specs then some one might be able to tell me. The bit i am worried about is the "unbalanced DC" but i am guessing that this will be a small number any way
600 - 600 Isolation Transformer - Used to provide isolation between Telstra lines and mains operated equipment..Austel Approved - Impedance: 600 line, 600 Equip. - Turns Ratio:1: 1 - Max Level: 0dBm @ 300Hz - Insertion Loss: 1dB max @ 0dBm300Hz - 5kHz - Freq Response: 300Hz~10kHz 1dB, 0dBm - Return Loss:<15dB, 300Hz-5kHz - Max Unbal. DC:60mA - Proof Test:4Kv RMS - (HWD): 30 x 41 x 33mm - Weight:153 Grams
Old 10th September 2012, 03:52 AM   #2
DUG is offline DUG  Canada
Isolation transformer in question is an audio transformer for speech.
"To go before my Variac."
If this is what I think you mean in that you would apply power (120/220VAC) to it as a power isolation transformer then NO, do not hook it up to line level power.
600:600 is in ohms recommended source/load.
0dBm in 600 ohms is about 0.77Vrms
Take care.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 10th September 2012, 03:57 AM   #3
AJT is offline AJT  Philippines
AJT's Avatar
Originally Posted by bullpeters View Post
Hi
don't even try.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 10th September 2012, 06:15 AM   #4
bullpeters's Avatar
Ok thanks. I am not real smart but not stupid either.
Ok so I want an Isolation transformer. I gather i need a suitably rated transformer with 1:1 turns ratio. Any thoughts were to get one? Preferably for not a lot of money
Old 10th September 2012, 06:24 AM   #5
AJT's Avatar
you need an isolation traffo about the same volt-ampere capacity as your variac...or at least as big as your biggest anticipated load....
Old 10th September 2012, 11:07 AM   #6
DF96 is offline DF96  England
The weight (153 grams) and size (30x40x33mm) ought to have warned you that this is not a power transformer even if the other technical details went over your head. It is meant for use in modems or telephones, to isolate the telephone line from technical faults and nontechnical users.
Old 10th September 2012, 11:16 AM   #7
just about every second word tells you this specification is not for MAINS' POWER.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th September 2012, 08:34 PM   #8
Enzo is offline Enzo  United States
1:1 transformers for mains isolation are specifically called isolation transformers. In catalogs they generally have their own page. I don't know what the surplus market is where you are, but in the USA we sometimes find them there cheaper than new.
I have been in the coin-operated amusements industry, which includes arcade video games. And all of them required an isolation transformer for their video monitors. As a result I have a number of iso's in my parts pile from them. You might look at some locel "operators" of arcade equipment and see if they have any old isolation transformers from video arcade games they would give up cheap. Can;t hurt to ask.
Old 16th September 2012, 08:09 AM   #9
Two identical AC power transformers wired back-to-back will operate just fine as an isolation transformer in most circumstances. AC mains power into transformer #1 primary, connect transformer #1 secondary to transformer #2 secondary and you'll have isolated power at just slightly less than AC mains power out of transformer #2's primary. There's a slight loss in voltage due to the conversion losses of the two transformers, but since you're also going to be using a variac and many variacs that I've seen will go 10% - 20% or so over the input level you should be able to compensate for the loss if you need to. Find two identical car battary chargers to donate the transformers and you'll get some pretty decent current levels. I like to fuse both the AC input (low amp) and the secondary-to-secondary connection (high amp) just to be super-safe. Here's a link I found using a quick Google search, not my site but it shows a schematic of connecting two transformers together:
Isolation JeeLabs
Newbie Question - Power Transformer vs Isolation Transformer SparkyPete Tubes / Valves 10 2nd November 2012 06:13 PM
Mains isolation - would this work? woodturner-fran Tubes / Valves 35 5th March 2008 01:33 AM
Cheap, Fast, Turntable Isolation: Sorbothane and the Enco Surface Plate DaveThreshold Analogue Source 5 21st April 2007 03:07 AM
Cheap Isolation Thatch_Ear Everything Else 0 29th May 2002 10:08 PM
Copyright 1999-2017 diyAudio
