Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 9th September 2012, 02:47 AM   #1
xxbaker is offline xxbaker  United States
Default Planer Doesn't Plane Flat
I recently purchased a Bosch PL1682 so I could make the sides of my cabinets perfectly flat. I've watched plenty of videos and spent quite a bit of time with the planer but I can't for the life of my get it to plane anything remotely well
The flat guides on the bottom don't seem to match up with each other and the right side seems to dig deeper than the left side so it cuts at a very slight angle so that multiple passes will create a series of waves and sharp dips/raises in the wood.
I'm scratching my head as to how this thing is supposed to work. Any tips/suggestions on how I'm setting this up wrong or doing this wrong? Every video looks absolutely effortless and in my experience it's anything but. Maybe this model is terrible? Or perhaps mine is defective? Thanks for the help!
Old 9th September 2012, 03:03 AM   #2
expert in tautology
bear's Avatar
Yours may well be defective.
If you have read the instructions carefully about set up, and followed them, I'd inquire of the company (assuming they have a means to communicate) and failing a solution there, return it under warranty, or to the store for replacement.
The blades do need to be properly cut and fit into the spinning chuck thing (whatever they call it), and the bed and guides need to be properly level - and if adjustable, properly set...
I don't know this particular planer at all...
_-_-bear
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 9th September 2012, 03:11 AM   #3
...truth seeker...
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
In your time with the planer, have you checked the position of the blades in the cutter head? Your description makes it sound as though the unit was not purchased new from the factory.
Is this the case?
Old 10th September 2012, 12:21 AM   #4
bill_a is offline bill_a  United States
xxbaker -
Sorry to disappoint, but hand-held power planers are notoriously poor at creating a flat surface, especially with multiple passes. They follow whatever surface is there to begin with, within the length and width of the base. If the base or knives are not perfectly aligned, you'll just end up making matters worse. And even when everything is really closely aligned, you'll still have to sand the h*** out of it to get it looking nice.
BTW, Bosch makes the best hand-held power tools, so you did purchase a good tool. Its just that hand-held power planers are really meant for cleaning up door edges and such, not making wide boards flat and smooth. People do try to use them for that, but that was never the original intent of the tool.
Just a little advise from a woodworker,
Bill
Old 10th September 2012, 03:30 AM   #5
Thanks for the advice and help everyone. I did buy it new so it's possible I can get it fixed/replaced under warranty if it isn't working correctly.
That being said I'm going to check the blade maybe it's not put in correctly or lined up. I checked the base it a straightedge and it looks to be quite flat so I'm guessing the blade isn't aligned correctly.
Perhaps I just need to get the right tool for the job as Bill has suggested, but maybe I can get this working well enough with some minor adjustments.
Thanks again for the help I'll try to check back when I figure out anything else.
Old 10th September 2012, 03:37 AM   #6
kevinahcc20's Avatar
Originally Posted by bill_a View Post
xxbaker -
Bill
Exactly so...to get a large surface flat it must be referenced to a flat surface of similar width and length. The job you are attempting would ideally be done with a jointer and/or a stationary planer. The other option is to develop a high level of skill with well tuned hand planes and scrapers and do it like the 18th century cabinetmakers. The tool you are using is fine for trimming door edges but will take you in the wrong direction for producing wide flat surfaces.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 14th September 2012, 05:23 PM   #7
Speakerholic
Cal Weldon's Avatar
I have to laugh. Not at you but with you as I can totally relate. Simple tip is don't try to plane anything wider than the blade. You just get yourself in trouble and end up running for the sander.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Flat FR, Flat Power Response, in-phase crossover? RockLeeEV Multi-Way 15 7th February 2012 08:07 PM
CSS planer 2 evanc Multi-Way 5 15th January 2012 09:38 PM
Derived Physics Model of a Planer ESL bshaw147 Planars & Exotics 17 2nd November 2008 08:12 PM
Planer 3 Esra Yeknom Analogue Source 11 29th January 2004 06:14 AM
Planer tweeters HarryHaller Multi-Way 7 16th April 2002 02:45 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
