Can you recommend a tube tester? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 8th September 2012, 03:18 AM   #11
HollowState's Avatar
I'm going to agree with speakerfritz and battradio on the Mercury 1000 and Eico 666/667. I own them both and like them. The TV7's are way over priced for what they do and have become a cult item. Full printed manuals with data are available from "glendalemanuals" on eBay at low cost.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 8th September 2012, 07:47 PM   #12
soulmerchant's Avatar
The Eico 666 is still a bargain, but you have to be careful with the manuals - the early ones are full of errors...
The only downside to the Eico is that it tends to give different readings every time (!)
I also have an avo MKII and have taken the time to restore and fully calibrate it - but I still use a DMM to accurately set the negative grid volts. It gives accurate results if you do this.
Some testers like the avo can be used to create crude plate curves. That is the main reason I have it.
If it is just to test if tubes are OK the the Eico 666 should really be fine.
Lastly - Never buy a tester where the mains plug has been cut off.
Ian
Ian
Old 9th September 2012, 09:38 AM   #13
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
Send a message via Skype™ to v4lve lover
the negative grid voltage needs to be measured by a MK8 avometer ive heard..
Kind regards
v4lve
Old 9th September 2012, 03:53 PM   #14
Thank you, All, for your guiding advice; you have given me some great ideas and suggestions. Fortunately I have time on my side and I don't have to make any rush decisions. Best wishes and (given ArtG's suggestion) if any of you are located in Minnesota US and would like to loan time, tester, or just expertise, don't hesitate to send me a private message.
Old 10th September 2012, 03:09 PM   #15
Kind regards
v4lve
Funny! Any true rms AC digital voltmeter can be used if you read the Avo manual and understand how the circuit is working. If the unit is correctly calibrated, negative grid volts set to 100 will give a reading of 52.5 on your rms AC digital voltmeter...
Old 10th September 2012, 10:48 PM   #16
Triodethom's Avatar
The Westom 981 type 3 or the heathkit tt1 copy . Had the Weston for 15 years worked well up dated the diodes checked the osc. tube . Price has gone up from the 20 dollars I payed at a hamfest.
Old 11th September 2012, 03:06 AM   #17
TBL is offline TBL  Hong Kong
I ams using a Mercury 2000 tester. It uses one tube and the results are quick. It has one downside, it does not individually test either of the two sides of a dual triode such as a 12AX7. It is a true bargain coz I had mine for something like US$250 including the case and the manual, in a fully working status.
WTB: Tube IMP or VTV Tube Tester or? bmenary Swap Meet 8 24th July 2011 10:39 AM
Help finding a tube tester for Stereo tube amps. Fasterdamnit Tubes / Valves 8 19th July 2010 01:43 AM
Recommend me a tube... Gordy Tubes / Valves 20 6th November 2009 05:30 PM
Please recommend a tube DAC to build. JayH3 Digital Source 1 26th May 2008 01:50 AM
Recommend an EL84 tube for HIFI ME2 Tubes / Valves 15 13th May 2007 03:13 PM
Copyright 1999-2017 diyAudio
