| Equipment & Tools From test equipment to hand tools |
#11 |
Almost necro-posting but anyways, I STRONGLY recommend the Uni-T UT61E.
The specs:
For example I decided to put this meter through its paces using some 0.1% resistors and some caps I had laying around. Link The resistors consistently showed an error of around 0.25-0.3% low, meaning that this meter could theoretically be adjusted to a much tighter accuracy. The downsides are that sometimes the probes have a layer of film on them that messes with readings. Supposedly, some isopropanol (rubbing alcohol) removes the film. |
#12 |
I purchased a used HP 3478A, on eBay, although it is old, it functions nicely for a 5-1/2 digit DMM. Flule 8050A is also nice if you need lower resolution.
The Uni-T UT61E sounds okay as well but it is not that accurate. Depends on your needs regards Rick |
#13 | |
LC200A Inductance Inductor Capacitance Capacitor L/C Multimeter Meter Tester | eBay |
#14 | |
For one that matches the Fluke specs in your price range check out the Mastech MS8218. It has a huge variation in prices I have seen as cheap as $120 and as expensive as $270, all for the same device. It's 0.03% accuracy, 50,000 count, TrueRMS etc. |
#15 |
Get a DMM that's auto ranging and with a big read out so when you have your hands in a high voltage circuit, you can read it without fireworks. I'd recommend a seperate cap/inductor meter because they don't get used that much. The cheap Radio Shack meters work great and last about 5 to 10 yrs. There will be times when you need 2 meters and these work nicely. I've had good luck... I'm sure not everyone will agree.........
The stuff you don't know always humbles us......... |
#16 |
I found this site to be helpful in narrowing the Fluke line, they have a nice table with features compared across the line:
Fluke Digital Multimeters - Test Equipment Depot I have no affiliation with this site. I have ordered a few things from them over the years, each time delivery seems to take longer than expected, but sometimes they have the best prices and they are responsive and polite if emailed etc. I have a Fluke 115 and am very happy with it FWIW. |
#17 | |
diyAudio Chief Moderator
#18 |
| Recommend eBay / China multimeter | wwenze | Equipment & Tools | 2 | 28th June 2012 10:47 PM |
| Digital MultiMeter? | nelsondog | Everything Else | 23 | 28th August 2010 10:42 PM |
| need help with getting a digital multimeter | ad_breaker | Parts | 14 | 19th February 2006 02:13 AM |
| which is good DIgital auto range multimeter. | boxedin | Parts | 8 | 23rd December 2005 03:57 PM |
| Digital Multimeter | speedstar | Digital Source | 2 | 20th July 2004 02:56 PM |
