Direct competitor for Clio V10 ? - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 23rd June 2013, 09:20 PM   #31
Smiley 09's Avatar
Lightbulb Firewire PCMCIA Express IEEE 1394
Originally Posted by Joe Rasmussen View Post
I need a portable laptop to run ClioFW/Windows/Firewire standard connector (old?)
But... need standard IEEE 1394 Firewire port to feel confident to buy, and now know that Firewire uses more than one type of plug.
Cheers, Joe
Hello Joe,
I have use these Adapter cards for Years for portable measurement with analyzers for some other things an they works flawlessly under W7 x64 (my case) on three different 17'' Lenovo notebooks and are fare better than orig. inst. on motherboard, they use Ti Chip, none inst. necessary, only plug it into a slot, (hot swap) and it works in a second.
- The most import. thing for fire-wire connection to function is:
DEINSTALL ALL MS garbage & Junk soft from the comp, close all services not needed and add a 1394a process to highest priority !!!
Min 2.core Proc, min 4, best 8GB RAM
If You Must use the comp for other things also frequently than make at least 2 user accounts and let it be the second - (MEASUREMENT) ONLY !! Please apply here all previously mentioned steps, and make You or ( Measurement) account - a full Admin. priority and use ur Meas. Syst. under full advanced (user - admin) properties ALWAYS (run as as administrator) and You'll work like charm !
If You want to work and not jocking than:
Don't buy a fancy look crap Acer or many other fancy super ultra light crap mini laptops !
Instead go to some local computer guru who each 2.yrs. replace the HiQ - engineered Lenovo WorkHorse Laptops in some fancy bankers or some other bureaucracy firms with the latest top models and get one 2.yrs. used
for a cheapo and You'll never look back or even regret !
For the money saved this way please make ur dearest some nice & tasteful dinners in some nice place You know they're do an You'll win win.....
Please see here You can order the best adapter 1394 Cards:
1. Firewire PCMCIA Express IEEE 1394
or for older laptops:
2. PCMCIA PC CardBus to FireWire IEEE 1394
Hope You'll begin work sooner before You become a $$ Golden Retriever
cheers:
Andreas:
Old 23rd June 2013, 11:06 PM   #32
Joe Rasmussen's Avatar
Originally Posted by planet10 View Post
Any MacBook Pro will do the job. Converting Firewire 800 to Firewire 400 is just getting a cable with 800 at one end & 400 at the other end. The newest MacBooks have Thunderbolt ports, an adaptor to Firewire is available from Apple and no one has had compatibility issues
Thunderbolt is a superset of Firewire/Display Port/USB/PCIe.
dave
Thanks Dave. That is exactly what I needed to know. I feel a lot more confident now. Yes, I noticed the missing optical drive too. But have an nice compact external one that I use with my Acer 13" laptop.
Thanks again... Cheers, Joe
PS: Found what looks like a Russian website re Clio on Macs, hit the translate button, and that seems to confirm exactly what you said in their somewhat broken English... good one.
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 28th June 2013, 12:10 AM   #33
Hi Dave
Bought MacBook Pro MD102X/A.
I also have a copy of Windows 8 but worried to break the seal as I know Clio FW works with Windows 7, but now find that Win8 Firewire support may not be up to it?
Cheers, Joe
Old 28th June 2013, 12:19 AM   #34
Hi Andreas
Some great info there, much appreciated. Some of it will be used even though I went the MacBook Pro way and will do a dual install. Dave is a Mac guy and it will please him I went the Mac way.
But that way I will have a laptop that can do all the things I need to do with it.
But the Windows setup, I will do a special Clio only user account and priority exactly the way you say. That is very good advice.
Had anybody tried Windows 8 with Clio FW?
Yes, Win 7/64bit will work, but if Win8 does too, then I would prefer it. I also have an unsealed version of Win8, but don't want to break the seal, as I can exchange it for Win7/64bit.
But thanks for your detailed reply and appreciated.
Cheers, Joe
Old 28th June 2013, 12:30 AM   #35
frugal-phile(tm)
planet10's Avatar
Around here people are staying away from Windows 8. I'd take yours back and trade it in on W7.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th August 2014, 06:38 AM   #36
ashok's Avatar
Default Clio-11 now !
The last post is over a year old.
Does anyone use the new Clio11-FW ?
What happened to the issues with Firewire. Will a new buyer be buying into outdated technology ( Firewire !) ?
Any idea if they are planning to make it USB2/3 compatible in any new version ?
Thanks,
Cheers.
AM
Old 24th August 2014, 07:18 AM   #37
tkollen is offline tkollen  United States
No, it doesn't seem so. I checked with them recently and they don't have any plans for USB-3. They claim difficulties with USB such as latency etc. With the outdated Firewire I think their product is now way overpriced (almost $2000). I have used my Clio 7 ISA-version until recently and rather than buying Clio 11 I decided to go with a good external USB-based sound card (like EMU 02/04) + Arta software (freeware) which is a low cost solution and a much better tool than Clio. I can now easily use my laptop for audio analysis using up to 32/196 sampling rate if I want.
Old 24th August 2014, 12:50 PM   #38
Originally Posted by tkollen View Post
Arta software (freeware) which is a low cost solution and a much better tool than Clio...
ARTA is not freeware.
BTW, I agree that they, Clio/Audiomatica, should move to USB. And I have told them so.
Cheers, Joe
Old 24th August 2014, 07:48 PM   #39
frugal-phile(tm)
planet10's Avatar
Firewire is not outdated tech. It is embedded in Intel's ThunderBolt (as id USB, PCI, DisplayPort, etc).
If one wants to use Clio, they should perhaps thinkof using a Mac running Windows (as Clio shows in their adverts)
dave
Old 25th August 2014, 01:20 AM   #40
Hi Dave
If one wants to use Clio, they should perhaps think of using a Mac running Windows (as Clio shows in their adverts)
Which is what I am doing. But with my desktop I have had intermittent problems with Firewire port, once it failed completely for both desktop and laptop and had to sent back to Audiomatica and including freight etc it was an expensive repair. Based on my experiences I have no great faith in Firewire, it still has intermittent issues and the Clio software just won't see it and I get the same error as if the ClioFW is not connected, have to disconnect, reboot - and sometimes many times during a prolonged session and you loose the settings you are using at that very moment - it can be very frustrating. Mind you, USB can be flaky as well - but maybe not to the same degree?
Having said the above, I will still continue to use Clio, but I just don't fully trust Firewire as reliable and I think they should make USB a viable option and also able to be used with any computer out there.
Cheers, Joe
Primare V10 DVD player troubles Kay Pirinha Digital Line Level 1 21st February 2012 03:32 PM
FS: SoundEasy v9/v10 speaker design software Eric Swap Meet 3 1st April 2011 12:20 PM
Power amp with current output, F1 competitor (kidding) PMA Solid State 26 26th September 2007 05:35 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
Is this a competitor? dshoaf Pass Labs 13 29th May 2005 08:32 PM
Copyright 1999-2017 diyAudio
