hewlett packard 54601a - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 24th August 2012, 08:21 AM   #1
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Default hewlett packard 54601a
Hi
Just picked a hewlett packard 54601a on the NZ version of Ebay for $180 USD.
Just wondered what people who own one think of them?? there dont seem to be any reviews online (due to age I guess?).
Any trick or things to watch for?
Cheers
Dagwood
If you keep digging in the garden of failure you will eventually find success
Old 24th August 2012, 03:08 PM   #2
macboy is offline macboy  Canada
We used those when I was in university (aka college in USA). I recall that they were intuitive and easy to operate, but also rather basic, as far as digital scopes go. The "autoset" feature actually worked quite well as I recall, which can not be said of all digital scopes. It seems to have a rather low sample rate (20 MS/s?) but like all digital scopes it will repeatedly sample repetitive waveforms to gradually build up a representation of the waveform. It has only an 8-bit vertical resolution, which is only "OK". It has trigger holdoff, which I really wish my digital scope had.
I recall that there was a special key sequence that you could hit (on the 'soft keys' under the CRT) that would enable a Tetris game easter egg. I forget what it is.
Make sure to go to the Agilent website and download the user and service manuals and any other documents that you may need. The availability of these manuals is a tremendous bonus for anyone acquiring used HP/Agilent lab gear. I came to own an old HP power supply, built in the mid 60's (over 45 years ago!) and just went to the Agilent site and downloaded the manuals. Amazing. I spent many hours trying to find manuals for my various other non-HP/Agilent gear, and never did find many of them.
Here is a page for all 546xx series:
Discontinued 54600 Series Oscilloscopes | Agilent
Documents for 54600B (manual is common for 00/01/02)
54600B 2 Channel 100 MHz Oscilloscope [Obsolete] | Agilent
In addition to the user/service manual, there is a "component level information package" which is more information like schematics, parts lists, etc.
Old 27th August 2012, 07:22 AM   #3
Dagwood's Avatar
Hi Macboy
Thanks for the info, I have saved a copy of the user and service manuals and will digest them while I wait for the unit to arrive from Christchurch.
Will suit me at this stage
Cheers
Old 29th August 2012, 05:11 AM   #4
VivaVee is offline VivaVee  New Zealand
They were a very early DSO and suffer from a low sampling rate. Any DSO that claims a 100MHz bandwidth these days would have a 1GS/s sampling rate. Regrettably your 'new' scope is equivalent to a 10MHz analog scope on anything except a steady sinewave. I recall my venerable 20MHz Hitachi analogue scope being significantly more useful. The digital Tek scopes from the same era were no better.
If this is your first and only scope then you would be advised to do a little reading so you understand its not inconsiderable limitations. On the other hand, this scope was quite useful at making a noisy switch mode power supply output look really nice because it ignored all the high frequency transient information!
Alan
"If you can not measure it, you can not improve it" - Lord Kelvin
Old 29th August 2012, 02:31 PM   #5
That is not an early DSO. My Tek 468 is an early DSO! 25 MS/s with no super-sampling capability. Claimed to have 10 MHz usable bandwidth in digital mode, but that's only true if you are OK with 2.5 samples per period. 1 or 2 MHz usable bandwidth is more like it. Luckily, it is also a very good 100 MHz analog scope (identical to a venerable 465B).
The HP is not only useful for sinewaves. Any repetitive signal within the bandwidth of the scope is going to be able to be displayed. However, there are limitations. Any signal component present that is not correlated to the trigger source is likely to end up being at worst, completely averaged out, or at best, simply appear as some low-level noise on the waveform. All digital scopes, at their fastest horizontal rates, use super-sampling to build up the representation of the waveform over several (sometimes many) repetitions of the waveform since the real-time digital sampling rate can never be high enough. 1 GS/s would be considered quite fast for real-time, but such a scope would likely have a >1 GHz analog bandwidth and at least 10 GS/s (likely much higher) "equivalent time" sampling rate.
The advice to learn about the limitations of equivalent-time vs. real-time sampling is good advice for anyone with a DSO, even a shiny new modern one.
Old 18th September 2012, 01:08 PM   #6
Years ago I tried to use one to do a "splat test" on an inductor (splat a charged cap across the inductor, measuring inductor voltage and current. if cap big, voltage ~ constant and current slope dI/dt = V_inductor/L so L can be calculated.
And I got precisely 3 dots in my measurement - whereupon I read the manual and found out just how low the single-shot sample rate was.
single-shot sample rate is perhaps a better term to use than real-time sampling rate - its self-explanatory.
the 546xx scopes also dont have much sample memory - so you need to be careful to avoid aliasing - if you cant trigger the scope but there's a nice looking waveform, its probably aliasing. I "discovered" this in my first real job, when my 12MHz 74HC14 xtal oscillator gave a ~20kHz output I couldnt trigger on - cue half an hour of frustration before a tech kindly turned the timebase knob for me.
Old 9th November 2012, 05:18 AM   #7
Dagwood's Avatar
Finally picked up the scope and when I got it home and fired it up this is what the screen looked like???
I have had a look through the manual but cannot find anything about screen settings
Any thoughts guru's??
Cheers
Old 9th November 2012, 01:17 PM   #8
For one thing, it is inverted. And compressed vertically obviously.
This looks like an issue with the vertical part of the CRT driver circuits. The horizontal seems OK, it is full screen width and nice and linear. And the displayed waveform looks fine, so it looks functional. I am not a CRT guy so I can't really help.
Old 9th November 2012, 01:33 PM   #9
Ouch... I can easily imagine how vertical compression could occur, but how do you get the image mirrored..? Perhaps someone tried to fix it and swapped a balanced line? As always, start by checking the supply voltages (with care, as dangerous voltages may be involved here).
Samuel
Old 10th November 2012, 01:34 AM   #10
Dagwood's Avatar
Hi Macboy and Samuel
Thanks for your thoughts
Damn...if it seems to good to be true it probably is!
I'm not keen on frying myself on this, may be better if I try to find a HP tech in New Zealand and get it looked at??
The Barney Oliver from Hewlett Packard jackinnj Solid State 45 26th November 2014 02:25 AM
Hewlett Packard 3478A Multimeter Calibrated dan45hk Swap Meet 5 18th February 2010 01:17 AM
Hewlett Packard 3478A Multimeter Calibrated (Dallas-Richardson) dan45hk Swap Meet 15 16th December 2009 07:17 AM
Hewlett-Packard on a iPhone peranders The Lounge 10 15th October 2008 09:47 PM
As you may know, the new "transistor" already arrived at Hewlett Packard. destroyer X Everything Else 8 4th February 2005 11:48 AM
Copyright ©1999-2017 diyAudio
