High voltage speaker connection? - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 20th August 2012, 09:47 PM   #1
Default High voltage speaker connection?
Hi, I'm designing a custom sound system using plasma speakers, and I need a medium-high voltage DC connection between the power supply and the amplifier - >200v. What's the voltage limit for the XLR connectors? What kind of connectors should I use? Any help would be welcome.
Old 21st August 2012, 04:23 AM   #2
DUG is offline DUG  Canada
a quick search for XLR at DIGI-KEY found a datasheet from CONNON for a 127007-010 that gave a pin 2 rating of 200V and 3-7 pin of 133V
This might be a little low for what you want.
RF coaxial cables have some high ratings.
BNC with RG-58 is rated for 500Vrms. Be very careful if you are going to put connectors on the coax by yourself.
DIGI-KEY is a great place to get data sheets on almost any electronic part...so many parts that it is difficult to narrow your search to what you actually want.
(no I don't own stock)
banana jacks vary with construction:
"Operating Voltage: Hands free usage in controlled voltage environments: 2500 Vrms maximum."
"Rated at 15 Amps, 5,000 VDC."
"Rated at 15 Amps, 1,000 VAC RMS."
Most of my DIY is built around what is available, either in my supplies, in surplus shops, or from "the big stores": Digi-KEY, Newark, Mouser, Allied, etc.
hope that helps
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
High voltage at speaker out Woody1911a1 Audio Sector 1 15th January 2011 07:31 PM
Why high voltage Fets when low voltage types gives less distortion? Circlomanen Pass Labs 21 9th December 2009 09:43 PM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
high voltage on speaker terminal marcus7601 Chip Amps 6 6th December 2006 06:54 PM
how to make high/lowpass filter in series connection??? limking Multi-Way 22 24th July 2001 03:50 PM
Copyright 1999-2017 diyAudio
