| Equipment & Tools From test equipment to hand tools |
#51 | |
I agree, there is a lot of useful information here. In fact, it was his website that sparked my interest in using ARTA and sound cards for spectral analysis. I plan to build his filter sometime soon. |
#52 | ||
I found out that my laptop generates a lot of noise with connected to the AC source. Pulling the AC jack and conducting ARTA test on battery only produce some great results in THD and THD+Noise. As suggested by BFNY, I also got better results from my HP239 Generator. 1. The first screen grab is my setup using Hp239 to E-MU-204 to Dell Laptop (AC/DC) supply connected. The results are to not pretty. 2. The next screen grab is the same setup but with the laptop on battery power. Big difference, but I still see some 60 Hz & 180 Hz artifacts. 3. The last screen grab Laptop on battery power and Low frequency cut-off set at 400hz. This trick I found playing around with ARTA. This really improved the THD + Noise figure by ignoring the AC artifacts I assume are from overhead lights or the HP239. I also found that my wife's Toshiba Laptop produced even poorer results both with AC/DC connected and on battery. So everything in the setup including the PC/Laptop can impact the results. I wonder if there are laptops that are manufactured with better shielding and power supplies. Last edited by dennismiller55; 20th September 2012 at 11:14 AM. |
#53 |
Dennis, I'm going to mess around with my ARTA this weekend and see if I can tweak it a bit more. My Tascam USB interface does not perform nearly as well as your E-MU. I'll post some pictures of my results. Also, I'm going to set the LFcut-off to 400hz as well and see what difference I get.
FWIW, I always use my laptops on battery when using this and any other analysis software. Dave |
#54 |
| ARTA | ente | Multi-Way | 150 | 25th December 2012 04:35 PM |
| A note about ARTA audio analysis software | richiem | Software Tools | 44 | 27th April 2011 04:58 PM |
| ARTA - using ARTA to measure room acoustics! | OMF | Software Tools | 0 | 25th November 2009 01:55 PM |
| ARTA help | Cousin Billy | Multi-Way | 2 | 13th February 2009 12:16 AM |
| ARTA Measurement Software | hongrn | Multi-Way | 1 | 2nd July 2006 07:46 AM |
