| Equipment & Tools From test equipment to hand tools |
I've got a four year old B&K 2534 DSO with the second channel losing it's high frequency response (all the way down to audio frequencies) as it warms up. I noticed this recently when I was running a 1KHz test on an amp. The leading edge started rolling off.
I suspect a component is failing and sensitive to temperature, which makes isolation a bit easier. Warm it up, put a signal in and start at the input testing components with "cool-spray". I emailed B&K requesting a schematic, but they have not responded. Does anyone have a schematic for this DSO? tks Steven |
#2 |
CH2 is now off the screen.
B&K did not respond to my request for a schematic. B&K wants $350 to repair it. I'll probably get another scope. Maybe a Rigol DS1102E. I think I'll pop the top on the B&K to see what it looks like inside. |
#3 |
I opted for a Tektronix 465M instead.
I may try to diagnose the B&K with it even if the parts do not have markings. At least I can isolate where the fault is. If a schematic ever becomes available I'll try to fix it. |
| DSO Nano or DSO Nano v2 | Dr Zeus | Equipment & Tools | 4 | 2nd March 2012 03:07 PM |
| Beginners Issue: Failing PA Amp | barnes | Solid State | 3 | 27th October 2010 05:44 AM |
| New DSO oscilloscopes - which one? | anatech | Parts | 20 | 26th May 2007 10:33 AM |
| Measure jitter with DSO ? | Bernhard | Digital Source | 0 | 17th June 2006 06:45 PM |
| DSO Bandwidth vs sample rate | bzo | Parts | 3 | 23rd February 2004 03:53 PM |
