| Equipment & Tools From test equipment to hand tools |
Hi all
I have this scope. Its the transistor fet version. It works great. Just busy calibrating it, and found that the channel 2 trace shifts upward when I pull the invert switch. Is this normal? If not how do I fix it. |
#2 | |
[I dont have schematic but you can buy on the internet a maintenance manual somewhere.] -RNM |
#3 |
expert in tautology
The balance pot I think is the screwdriver adjust on the front panel.
I was able to get the balance to work pretty well, but it wasn't terribly good down to the lowest range or two... _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
| Should I recap a working Tek 453? | Bill Fuss | Equipment & Tools | 5 | 12th December 2010 02:43 PM |
| Tektronix 1101a Psu & P6201 Fet Probe | GeeVee | Parts | 1 | 8th November 2007 11:18 AM |
| Threshold FET 10/pc Phono Stage Preamp Schematics aka FET 10pc, FET-10pc, fet ten/pc | krellkraver | Solid State | 1 | 8th February 2007 03:05 PM |
| User Manual for Tektronix 453 | hifileslie | Parts | 2 | 14th March 2004 06:31 PM |
| Yikes!! FET Substitution? Could use some FET Guru's here... | EchoWars | Solid State | 15 | 9th February 2004 07:08 PM |
