BK 707 Tube Tester Mods - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 24th July 2012, 09:17 PM   #1
mbeards is offline mbeards  United States
Default BK 707 Tube Tester Mods
I have a Bk 707 that works pretty well. Planning on going through the calibration process this evening after installing a SS rectifier.
I have heard of a simple mod to better test 12AX7's and while its all opened up, I am trying to think of other modifications for more comprehensive testing.
I plan on adding an ammeter to the common cathode circuit to "match tubes" or more correctly, get a better sense of performance and compare sections of twin triodes.
(I say "more correctly" since matching isn't quite possible at a static point.)
Are there any adverse affects of simply adding an analog ammeter inline with the cathodes? Also what is a good current range with this tester?
Also, this may be more trouble than its worth, but a headphone noise test would be pretty cool.
Any thoughts are greatly appreciated,
-Matt
WTB: Tube IMP or VTV Tube Tester or? bmenary Swap Meet 8 24th July 2011 10:39 AM
Tube Tester maxseeley Equipment & Tools 0 5th January 2011 05:08 AM
Do you have a tube tester? pforeman Equipment & Tools 2 17th December 2010 04:25 PM
Help finding a tube tester for Stereo tube amps. Fasterdamnit Tubes / Valves 8 19th July 2010 01:43 AM
tube tester TJ Equipment & Tools 11 5th April 2005 02:23 PM
Copyright 1999-2017 diyAudio
