Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 24th July 2012, 03:33 AM   #21
zigzagflux's Avatar
Been using Weller electronic soldering station with Weller tips for maybe 10 years. I always clean the tip as follows:
Run to around 700F.
Clean thoroughly with damp sponge.
Melt a big glob of solder on the tip, making sure entire tinned surface is covered with excess.
Turn off heat.
Immediately shake off the excess onto a paper towel. Shake it hard 2-3 times. What is left is no rosin, just a thin layer of solder, still drying.
Never had a problem with a tip. The only time I have issues is when I am too harsh on my tip mechanically. They don't like to be used as screwdrivers.
Old 23rd August 2012, 07:26 AM   #22
Hi again,
Based on the tips I have gotten from you I have now found a way to keep my tips reasonably/quite clean:
I don't use much water on the sponge - and probably something similar to demineralized water (from my water cleaning bottle)
I don't leave the iron turned on for long after last use
I sometimes switch off the iron when there's a new drop of tin on both sides - seems to clean the tip so that when I start up the iron again it is clean on both sides.
This works fine for me - so unless others would like to share their approach I'm quite fine with matters now ;-)
Greetings & thanks,
Jesper
... Being mindful about sustainability also in my audio endeavors matters to me ... paying CO2 - and a quite fair pollution - compensation helps create a good listening "energy" ...
Old 7th December 2012, 06:27 PM   #23
I purchased a Weller SP-23, their "consumer" or hobby version of the 25W iron. The MT-series tips for these are absolute cr*p. Yes, I properly clean them (damp sponge) and try not to keep them on without use, but they will pit very quickly. I use 63/37 eutectic solder so it should not be a problem. Tips cost $7 per pair.
I now make my own soldering iron tips and they work very well. I use 3/16" brass or bronze rod from the hardware store. I thread the end using a #10-24 die, then cut to a 2" length, chuck it into a drill and sharpen the tip portion against a belt sander. It takes 10-15 minutes, saves a lot of money, and the tips have lasted significantly longer than factory ones.
The additional advantage: you're not stuck with the factory shapes. I can now make any shape or profile iron tip I want.
Old 1st January 2013, 06:10 AM   #24
A note on ammonia.
Ammonia attacks copper. I'm new to electronics and still honing my soldering skills, but I'd think If you have the older copper tips or if your iron coat has worn and copper shows through, that ammonia would viciously attack the copper.
Ammonia is the main ingredient in brass polish and gun "copper fouling" solvent. Copper jacketed bullets leave behind layers of copper that must be removed after shooting, and the stuff is so strong it'll knock you on your butt (see Sweets 762 or Barnes CR-10).
Something to think about.
Old 1st January 2013, 09:46 AM   #25
cihtog is offline cihtog  United States
Before I learned proper tip care and soldering technique many years ago, I was going through tips, almost as often as solder. Nowadays, the only thing to touch the tip of my iron (besides flow from heating the part and the pad, not the solder) is a well wrung sponge.
I can't remember the last time I replaced a tip - and I certainly have yet to sand on one either (at least not in the last couple of decades anyway). I'll even go as far as to frequently wipe the tip, just for the sake of keeping it "just tinned".
FS: New Weller WESD51 Soldering Station $100 DreadPirate Swap Meet 1 22nd February 2012 01:13 PM
"sensorless" soldering iron temperature control star882 Parts 3 24th May 2009 08:44 AM
Weller soldering iron problem rtarbell Parts 2 23rd June 2007 04:48 AM
FS Weller WS81 Soldering Station powertriode Swap Meet 1 19th June 2006 01:10 PM
FS : Weller Butane Soldering Iron pho_boi Swap Meet 0 8th January 2005 10:32 AM
Copyright ©1999-2013 diyAudio
