Intermodulation thd measurements using pc usb scopes or usb sound cards - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 2nd July 2012, 07:54 AM   #1
Default Intermodulation thd measurements using pc usb scopes or usb sound cards
Hello
I do electronics as a hobby but my budget are very limited, so I can't afford a real spectrum analyser.
I need to measure distortions down to -95 db in FFT mode.
And I've made a 16 signals low distortions sinewave generator for complex signals intermodulation thd measurements using the FFT, here's the frequencies: 22, 30, 52, 83, 123, 199, 316, 499, 802, 1248, 1998, 3152, 4997, 7997, 12498, 19997.
Wich affordables pc usb scopes or usb sound cards, in FFT mode, can do those measurements and without having intermodulations ?
Thank you
Bye
Gaetan
Old 2nd July 2012, 09:10 AM   #2
jan.didden's Avatar
You must be carefull with USB scopes because most (except the expensive ones) are only 8 bit vertical resolution. That means you can measure at most to -48dB...
I have only a little experience with sound cards but there are cheap 24bit/96 or 192kHz sound cards which would be much better suited.
Software like ARTA will also function as a scope with a sound card.
With the 24bit/96kHz you can measure to 48kHz at better than -100dB.
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 2nd July 2012, 09:27 AM   #3
Hello
I can have a M-Audio Transit usb sound card for a very good price, any opinions about this usb sound card ?
What bug me are the level of intermodulations thd of a usb sound card with a multi-signals sinewaves of 16 frequencies.
Thank
Bye
Gaetan
Old 2nd July 2012, 03:35 PM   #4
DF96 is online now DF96  England
I think some USB scopes can do signal averaging to improve resolution. You can also build a notch filter for the fundamental - a passive twin-T will help.
Old 2nd July 2012, 11:18 PM   #5
richiem is offline richiem  United States
richiem's Avatar
I'm using an E-MU 0204 USB sound card -- 192kHz ADC & DAC, 24-bits -- (mine was about $105 US) to do high resolution THD analysis in conjunction with ARTA. This combination, at least for mid-band audio signals, offers accurate measurements well below -110dBu. The EMU and ARTA together resolve a 1kHz low-distortion sine down to about 0.0002%. Then I add an Active Twi-T notch filter ahead of the EMU to remove the fundamental by 40dB or more, and the resolution increases to better than 20dB lower. See the results given by these tools on my webpage about a rebuild of the Heath IG-18 oscillator into Bob Cordell's state-variable design here (there is a page on my site also for details of the active Twin-T):
IG-18 #2, the BIG-18
For looking at signals above 15kHz, there is no great solution. I can see the 4th harmonic of 20kHz, but not higher, since the antialiasing filtering cuts them off, and even so, the noise floor has a pretty steep rise above 30kHz, due to noise-shaping in the sigma-delta converter. ARTA will do nice twin-tone IMD too, but as you mention, cross-modulation garbage sets a real limit to resolution.
I've been frustrated by the low resolution of available USB scopes -- there's one that's 12 bits (Stingray) and is moderately priced, but it's only good for 200kHz max. Any with more BW are at most 10-bits. Given that there are plenty of ADCs now available for more resolution and BW, I don't know why we aren't seeing them in the market....
Will wireless USB hub lower the quality of my USB sound card output? rg12 Digital Source 6 6th January 2011 08:47 PM
Anyone tried those cheap usb sound cards? Westerp Digital Source 1 5th May 2009 09:47 PM
Are there *any* good premade USB sound cards? 8086 Digital Source 10 24th June 2008 05:52 AM
CLIO-Win7...compatible with USB sound cards? ashok Everything Else 2 31st December 2005 11:41 AM
Copyright 1999-2017 diyAudio
