Dayton EMM6 bias voltage - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 24th June 2012, 01:57 PM   #1
ashok's Avatar
Default Dayton EMM6 bias voltage
The Dayton EMM6 microphone has a bias voltage rating between 15 to 48 Volts.
Sensitivity is given as 10mV/Pa .
Will this change with the bias voltage ? I think it shouldn't but would like some confirmation from someone who knows.
Apart from the mic capsule, what else is inside the mic body ?
Thanks.
AM
Old 10th July 2012, 04:04 AM   #2
ashok's Avatar
No one appears to have read this thread or has no answer.
Well, I found that it appears to make no difference to sensitivity if the phantom voltage is varied. The mic usually has a built in zener that keeps the 'internal' voltage fairly stable within a range of external phantom voltages.
AM
Old 16th July 2012, 12:58 PM   #3
ashok's Avatar
I rigged up a phantom supply for the EMM6 and got the following results.
Phantom voltage 41 volts .
Series resistor on pin2 and 3 = 6.74K
Voltage at the pins 2 and 3 = 32.1 V
Current flow into each pin = 1.32 mA
Phantom voltage 16 volts
Series resistor = 6.74K
Voltage at pin 2 = 8.99 V and pin 3 = 8.95 V
Current flow (average ) about 1.04 mA
That seems to be low as I expected to see about 4 mA based on data seen somewhere on the Net. Anybody else checked this ?
Looks attractive for the single battery split supply rails at +/- 9V.
AM
Old 16th July 2012, 02:29 PM   #4
With a lower phantom power voltage you should reduce the resistor values in the supply lines. The attached graph, taken from the "Handbook for Sound Engineers" has served me well with different mics. The sensitivity, with a well designed circuit, should not change
Cheers, E
Old 17th July 2012, 05:42 PM   #5
ashok's Avatar
Thanks mickeymoose.( nice name !). Appropriate for Canada !
That chart should be useful. I will check sensitivity with different phantom voltages. Will also check with Dayton if they have a recommended chart of their own !
Thanks.
Cheers.
AM
Old 25th July 2012, 02:56 PM   #6
ashok's Avatar
Default Phantom voltage from 9 V battery
I built a voltage tripler with a 7555 chip for getting the phantom voltage for the mic from a 9 V battery.
Here are the test results with a new battery. There is a 22 ohm resistor in series with the battery and the circuit . The resistor and a 100uF capacitor is just to filter the supply a bit.
On load battery voltage at the chip 9.6V
Multiplier output dc voltage 27.4 V without load.
Multiplier operating frequency 61.9 Khz
Multiplier output voltage on load ( mic connected) 18.9 V
Voltage at the mic pins 10.8 V
Resistor in series with the phantom voltage and the mic 6.8K ( x2)
Battery current with no load 1.2 mA
Battery current with mic connected 8.2 mA
Ra/Rb/C on the 7555 4.7K / 10 k / 2 x 470 pF ( 940pF).
The multiplier circuit uses 4 x 1uF ( mini box type ) and 4x 1N4148.
I will try it later with a bench supply at lower voltages and see what happens. Should be OK till about 7.6 V I think.
Wonder how low the mic will really accept without loosing sensitivity ......14V ?
Right now I'll be using two batteries to get +/- supplies for the mic amp. Will work on the -ve supply scheme from a single battery to make the whole system work off one 9 V battery.
I haven't drawn out a schematic but if anyone really wants it I can put one up later. Just a simple astable with a multiplier attached to the output.
AM
Exceeding bias voltage? rntlee Tubes / Valves 15 3rd May 2012 09:57 AM
FS:Maya44 pci and Dayton EMM6 mic drptpcpe Swap Meet 4 19th February 2012 03:38 PM
dayton wright st300a matching / bias trnsformer unit krmaudio Planars & Exotics 14 21st October 2010 12:05 AM
Bias Voltage AmpBuilder225 Tubes / Valves 4 17th March 2009 11:27 AM
bias voltage vs bias current woodturner-fran Tubes / Valves 3 24th February 2007 11:24 PM
Copyright 1999-2017 diyAudio
