Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 21st June 2012, 05:01 PM   #1
ColinAlex's Avatar
Default Tek 2465B 400 MHz scope for starting out?
I'm just starting out in the DIY world and am looking for a scope that will last a while. i.e. not need replaced due to capability short-comings. My interest is in building analogue components starting with a TT power supply and phono stage. An active crossover would probably be next (orion kit), then who knows. Would this be an appropriate scope?
Tektronix TEK 2465B 400 MHz Oscilloscope ----Late Hour Calibrated | eBay
Thanks in advance for any feedback.
Your successes can lie to you but your failures never do.
Colin
Old 21st June 2012, 06:12 PM   #2
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
Below you can see what kind of s uck s is expected with such an instrument ....
Tek 2467B very nice, with problems.
But if you're duly resolute, may be you have a great instruments that is more than enough for audio.
I'll try to gather my thoughts.
But this is difficult because here it is very hot.
And I do not can in English.
Ps.:
By the way I like your signature.
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 21st June 2012, 06:35 PM   #3
Gyuri's Avatar
You can expect to be addressed with the instrument.
It is strongly recommended, replacing the power supply capacitors.
The board A5 leaking capacitors can cause problems.
I think the price is good anyway.
But, it is contains a test lead?
Because if not, the matching P6137 is quite expensive:
Tektronix P6137 400 MHz Oscilloscope Probe New Sealed - eCrunch - Call us toll free (888)449-7653
From this now, four pieces would be needed
I got for mine two pieces, for €185.
Old 21st June 2012, 06:41 PM   #4
macboy is offline macboy  Canada
Less expensive generic probes can be used without issue, as long as they can be adjusted to the input capacitance of the scope (and they usually can). Finding inexpensive 400+ MHz probes is difficult, but 250 MHz ones are easier to find, and 250 MHz still easily exceeds what is needed for audio use, even if they are slightly below the capabilities of the scope.
Old 21st June 2012, 06:47 PM   #5
Gyuri's Avatar
That's true, they are for me cheap leads like this.
The trouble is there if somebody is maximalist.
Old 21st June 2012, 06:48 PM   #6
ColinAlex's Avatar
I have enquired about test leads from the seller. Thank-you for pointing out price of replacing them.
Colin
Old 21st June 2012, 06:59 PM   #7
ColinAlex's Avatar
Thank-you macboy. The 250's are a reasonable price.
Colin
Old 21st June 2012, 07:11 PM   #8
Gyuri's Avatar
Anyway, I have a Tektronix 2225 oscilloscope.
I like this very much.
This is also more than enough for audio.
It has a very nice function, which is the 500uV/div setting.
Old 21st June 2012, 07:49 PM   #9
ColinAlex's Avatar
It seems this scope is as much as I'm ever likely to need. Are there any reasons to avoid this particular model?
Colin
Old 21st June 2012, 08:16 PM   #10
Gyuri's Avatar
I do not know such a thing.
So which Tek scope should I look for? tonyptony Equipment & Tools 12 1st March 2013 07:26 PM
Tek Scope FS, EBAY a.wayne Equipment & Tools 2 22nd June 2011 06:26 PM
Upgrading to the TEK 2465B Bryan Everything Else 1 26th November 2005 02:42 PM
10 Mhz Scope enough ?? Henrik Juhl Equipment & Tools 24 20th October 2004 06:05 AM
Tek 465 Scope Bryan Tubes / Valves 3 30th October 2003 09:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
