| Equipment & Tools From test equipment to hand tools |
#11 |
Probably the easiest way to do sine wave between 0-10MHz (and more) is to use a DDS synthesizer IC. If you have some knowledge in micro-controller programming, you can do all by yourself. Otherwise, you can buy one already build from many different source. You can look this one, it seem interesting for your needs(but limited to 5MHz). Also this one, up to 20MHz. Regards. Frex
DIY CS5381 ADC / DIY 10kHz Super Oscillator / DIY DC-1MHz RMS-DC converter & 60dB LNA . Last edited by Frex; 9th June 2012 at 11:04 AM. |
#12 |
#13 |
Thanks to everyone for their inputs. I am considering the various options.
Unfortunately the MAX038 is obsolete so I am not keen to use it. In the UK/Britain/England second hand test equipment is expensive because of lack of supply. In my experience the UK electronics industry is small and has low budgets for buying stuff. Stewart of Reading list an HP3312A at £ 175.00 and a Wavetek 185 at £ 150.00. I don't really want to spend money on 20 to 30 year old stuff that could have reliability problems when new equipment (from TTI, not best quality though) isn't that much more expensive. Thanks for the suggestion of looking at the Wavetek 185 schematic. I have downloaded a copy but it doesn't look very easy to recreate. I only want a limited frequency range and sine only which does simplify the circuit a bit though. I have used varicap diodes with crystals for frequency trimming and with effort could make up oscillators and a mixer but I am not sure how easy that is. I might just splash the cash on something new rather than spend a long time on the problem. |
#14 |
I am just concluding this thread. I have just bought a Thurlby Thandar Instruments TG1000 10 MHz DDS Function Generator. The Sine output at 10 MHz looks pretty clean on the Oscilloscope which is good enough for my requirements. I am using it to measure amplifier open loop gain.
| High frequency sine wave on the LM1036 output | daniel23 | Chip Amps | 37 | 22nd November 2011 12:13 PM |
| Sine Wave Generator with bulbs (Sine-lightenment) | Rodeodave | Everything Else | 6 | 21st July 2008 12:19 PM |
| Sine wave - Square & Triangle wave generator using Transistors / OP-Amps | lineup | Solid State | 20 | 9th October 2006 12:15 AM |
