Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 1st June 2012, 08:54 PM   #1
Default Just bought Aoyue 936, now what solder to buy?
I just bought the Aoyue 936 solder station, and now I need some solder to use with it. Can anyone recommend me some nice solder thats good to be used on soldering electronics. My first project is the O2 headphone amp, and things like that will be the main thing I need solder for.
Would be nice if you could give me a link to ebay with the solder you reccomend.
Thanks!
Old 2nd June 2012, 05:19 PM   #2
Here you will find a lot of info. The solder you choose is up to your application: Kester - Connecting Innovation > Side Menu > Technical Support > Knowledge Base
Happy soldering! E
Old 2nd June 2012, 05:35 PM   #3
Banned
60/40 tin and lead or eutectic.
Don't use lead free unless you have too.
Old 2nd June 2012, 07:03 PM   #4
mickeymoose, thanks for the link!
Alvis: thanks for the tip.
Bought this: 60/40 Tin Lead 1.8-2.2% Flux 0.8mm Dia Soldering Wire Reel | eBay
Old 3rd June 2012, 05:10 PM   #5
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
make sure you buy something to keep the tip clean and shiny, regularly tin the tip, look after it as its the only one you are going to get, theres no way afaik to change the element in the iron, or have they changed this? I have them some pretty harsh feedback about that
Old 3rd June 2012, 07:59 PM   #6
Package content:
936 station
B001 Soldering iron
2630 Soldering iron holder
C001 Soldering iron spare heating element.
Also bought an extra tip:
Aoyue T-SI Conical Type Solder Tip for 936 937+ 768 968 | eBay
Old 4th June 2012, 03:08 AM   #7
Banned
I have the little wet sponge, I give the tip a quick swipe before AND after use.
*The hot rosin is corrosive, so having the tip clean while it sits there idle makes them last much longer.
Every once in a while I lightly sand the rest of the tip when it gets all black, it keeps dirt from migrating down to the tip.
Old 4th June 2012, 05:13 AM   #8
qusp's Avatar
the wet sponge is not a good idea, it cycles the temperature and oxidized the tip, which is the enemy, the brass wool cleaner will make your tips last much longer
Old 4th June 2012, 05:15 AM   #9
qusp's Avatar
Originally Posted by everlong View Post
they must have changed the design after complaints. I bought the same one a couple of years ago and it was not able to change the element
Old 4th June 2012, 11:47 AM   #10
Banned
Who cares if it cycles the temp, you sound silly.
Brass wool cleaner does not make your tips last longer, because the hot rosin is constantly oxidizing the tip. I promise.
A wet sponge is all you need.
Best solder? where to buy? stargeezerme Equipment & Tools 32 29th February 2012 03:03 AM
Hakko 936 - is this a good deal? kingby Equipment & Tools 3 27th January 2010 04:31 PM
Tips for Hakko 936-12 Dido Tubes / Valves 7 20th December 2005 01:55 PM
Hakko 936-12 TheDriver41 Equipment & Tools 7 24th October 2004 12:52 AM
Group buy on Sn96.5 Ag3.5 solder... dkemppai Swap Meet 5 12th December 2003 02:26 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
