Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 4th May 2012, 10:16 PM   #31
akis is offline akis  United Kingdom
I have tried 8 or more relays, 5 are OK-ish, 3 did not work. One was probably defective (stayed always on even with DC load - PVD1354N), another had very big leakage in the off state (ASSR-5211). All measurements at 200 KHz. I am slightly worried that these things are not very reliable...
So the (very experimental) breadboard device so far is : +/- 6V DC power, oscillator (200 KHz, 4V peak), push-pull output stage, 1:12 transformer to raise the voltage to 50V peak, load of 1K at worst, 2K at best.
Next item will be the switching of the transformer's output to channels 1-2, or 1-2-3, or 1-2-3-4.
Final item will be monitoring: overloading (current limiting), correct frequency, battery low.
Forgot to say:
I am planning to have some sort of CMOS logic that will switch those relays on and off - that is why I looked at 5V relays only.
The signal source is the output of a transformer, it is floating, and those opto-isolated relays are ideal. If I used a FET for switching there would need to be some relationship between Gate and Source/Drain - but I'd rather the output of the transformer be completely unknown to the rest of the device. I think
Old 4th May 2012, 11:36 PM   #32
jackinnj's Avatar
Teledyne has mechanical relays used on a mission to circle the former planet "Pluto"! My Teledyne 712's will do "only" 10 million cycles.
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
high frequency high voltage power supply... moray james Planars & Exotics 6 23rd July 2008 07:57 PM
High Current relays for speaker switching? Zero Cool Everything Else 13 15th December 2006 11:52 PM
Using relays in high voltage circuits Gunders Tubes / Valves 33 18th February 2003 09:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
