J406 substitute? - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 20th March 2012, 08:13 PM   #1
raul_77 is offline raul_77  Europe
Default J406 substitute?
This is a very interesting circuit:
Doble Trazo.pdf Trazo.pdf
To convert a single trace oscilloscope in a double trace for very little money, and work up to 20MHz.
Can be buy a good cheap scope of a single beam, as a Hameg HM-103, and make double-beam, which is very useful.
The problem is that can't find the J406. Any suggestions to replace it?
Happy days.
Old 20th March 2012, 08:37 PM   #2
PChi is offline PChi  United Kingdom
Linear Integrated Systems at Linear Integrated Systems - Home Page list a substitute but I don't know if it's really possible to buy them.
Old 20th March 2012, 09:17 PM   #3
Hi PChi,
Thanks for your kindness.
Happy days.
Old 23rd March 2012, 02:56 AM   #4
Well. LS845 seems that also is not available.
Any other ideas? Maybe some way to replace the input circuit?
Happy days
Old 23rd March 2012, 06:39 PM   #5
Farnell list an NXP - PMBFJ620,115 dual N Channel FET. I haven't checked the data sheet.
I guess that FT1 is a dual FET so that the dc offset betwen the two inputs is low. But then R12 offsets the traces anyway. As performance is compromised why not just use two single JFETS and save up for a dual trace Oscilloscope.
Old 23rd March 2012, 07:09 PM   #6
Thanks again. Yes, no problem to use two single JFETS.
What do you recommend easy to find?
Happy days
No Substitute for... mcd99 Subwoofers 8 16th January 2011 01:58 PM
EL3N substitute ervinl Tubes / Valves 2 21st October 2010 05:43 PM
Gallien Krueger 250ML overdrive.. (J406/J412???) sm3000 Instruments and Amps 2 19th May 2009 02:11 PM
Transistors Substitute ali_moinuddin Solid State 11 27th October 2008 03:23 PM
Substitute for mosfet darkm4n Parts 2 23rd April 2007 10:57 AM
Copyright 1999-2017 diyAudio
