| Equipment & Tools From test equipment to hand tools |
#11 |
Hey, Tom,
Thank you for your reply! I took on the middle of the things, extremely possibly. The oscilloscope works, as you may see on this picture: https://public.bay.livefilestore.com...are.JPG?psid=1 You may see it though on this picture, there is a Dallas DS1225Y chip: https://public.bay.livefilestore.com...-06.JPG?psid=1 The battery is in it. Similar, that was on EISA motherboards. Who remembers EISA MCA architectures yet? MYLEX is the name of few for example. I don't think that there is a need for full calibration. Than I mentioned it above, there is a vertical mismatch. The representation of the signs is perfect. The trigger is stable, on all four channels. Brightness, focus, astigmatism these are sems to be properly. The cursor readouts are perfect, at volts and frequencies too, but only in manual mode. But the CH1 VAR VOLTS/DIV as if it would not function properly. But the potmeter is all right, tested with DMM, according to CH2 VAR potmeter, which is works perfectly. AUTO SETUP is out of order, as all of automatic measurements. For your reference, the Service Manual found here: https://skydrive.live.com/?sc=photos...1531&sc=photos Thanks for your help in advance! Gyuri
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat Last edited by Gyuri; 8th April 2012 at 10:29 AM. |
#12 | |
Description The DS1225Y 64K Nonvolatile SRAM is a 65,536-bit, fully static, nonvolatile RAM organized as 8192 words by 8 bits. Each NV SRAM has a self-contained lithium energy source and control circuitry which constantly monitors VCC for an out-of-tolerance condition. When such a condition occurs, the lithium energy source is automatically switched on and write protection is unconditionally enabled to prevent data corruption. The NV SRAM can be used in place of existing 8k x 8 SRAMs directly conforming to the popular bytewide 28-pin DIP standard. The DS1225Y also matches the pinout of the 2764 EPROM or the 2864 EEPROM, allowing direct substitution while enhancing performance. There is no limit on the number of write cycles that can be executed and no additional support circuitry is required for microprocessor interfacing. Last edited by KatieandDad; 8th April 2012 at 10:39 AM. |
#13 |
Now I see, between 2465 and 2465B are more differences than 2465B and 2467B between.
http://www.us-instrument.com/objects...ge/img2300.jpg http://www.us-instrument.com/objects...ge/img1006.jpg
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat |
#14 |
So, dear Flg, if you have less button, it is a 2465.
#15 |
It is because of this that Tom's machine some other kind of battery contains.
#16 |
As my learned colleague would say it:
Stand on half foot while somebody helps you. I say it, help yourself, and the God helps you. He helped me already. Although I would have omitted this rather.
#17 |
I found this beautiful side while I was searching for useful informations on the web:
Audio, Verstärker, Meßgeräte und analoge Elektronik
#18 |
Laurie Anderson: Only An Expert Now only an expert can deal with the problem Because half the problem is seeing the problem And only an expert can deal with the problem Only an expert can deal with the problem So if there’s no expert dealing with the problem It’s really actually twice the problem Cause only an expert can deal with the problem Only an expert can deal with the problem Now in America we like solutions We like solutions to problems And there’s so many companies that offer solutions Companies with names like Pet Solution The Hair Solution. The Debt Solution. The World Solution. The Sushi Solution. Companies with experts ready to solve the problems. Cause only an expert can see there’s a problem And only an expert can deal with the problem Only and expert can deal with the problem Now let’s say you’re invited to be on Oprah And you don’t have a problem But you want to go on the show, so you need a problem So you invent a problem But if you’re not an expert in problems You’re probably not going to invent a very plausible problem And so you’re probably going to get nailed You’re going to get exposed You’re going to have to bow down and apologize And beg for the public’s forgiveness. Cause only an expert can see there’s a problem And only an expert can deal with the problem Only an expert can deal with the problem Now on these shows, the shows that try to solve your problems The big question is always “How can I get control? How can I take control?” But don’t forget this is a question for the regular viewer The person who’s barely getting by. The person who’s watching shows about people with problems The person who’s part of the 60% of the U.S. population 1.3 weeks away, 1.3 pay checks away from homelessness. In other words, a person with problems. So when experts say, “Let’s get to the root of the problem Let’s take control of the problem So if you take control of the problem you can solve the problem.” Now often this doesn’t work at all because the situation is completely out of control. Cause only an expert can deal with the problem Only an expert can deal with the problem Only an expert can deal with the problem So who are these experts? Experts are usually self-appointed people or elected officials Or people skilled in sales techniques, trained or self-taught To focus on things that might be identified as problems. Now sometimes these things are not actually problems. But the expert is someone who studies the problem And tries to solve the problem. The expert is someone who carries malpractice insurance. Because often the solution becomes the problem. Cause only an expert can deal with the problem Only an expert can deal with the problem Only an expert can deal with the problem Now sometimes experts look for weapons. And sometimes they look everywhere for weapons. And sometimes when they don’t find any weapons Sometimes other experts say, “If you haven’t found any weapons It doesn’t mean there are no weapons.” And other experts looking for weapons find things like cleaning fluids. And refrigerator rods. And small magnets. And they say, “These things may look like common objects to you But in our opinion, they could be weapons. Or they could be used to make weapons. Or they could be used to ship weapons. Or to store weapons.” Cause only an expert can see they might be weapons And only an expert can see they might be problems. Cause only an expert can deal with the problem Only an expert can deal with the problem Only an expert can deal with the problem And sometimes, if it’s really really really hot. And it’s July in January. And there’s no more snow and huge waves are wiping out cities. And hurricanes are everywhere. And everyone knows it’s a problem. But if some of the experts say it’s no problem And other experts claim it’s no problem Or explain why it’s no problem Then it’s simply not a problem. But when an expert says it’s a problem And makes a movie and wins an Oscar about the problem Then all the other experts have to agree that it is most likely a problem. Cause only an expert can deal with the problem Only an expert can deal with the problem Only an expert can deal with the problem And even though a county can invade another country. And flatten it. And ruin it. And create havoc and civil war in that other country If the experts say that it’s not a problem And everyone agrees that they’re experts good at seeing problems Then invading that country is simply not a problem. And if a country tortures people And holds citizens without cause or trial and sets up military tribunals This is also not a problem. Unless there’s an expert who says it’s the beginning of a problem. Cause only an expert can deal with the problem Only an expert can deal with the problem Only an expert can deal with the problem Only an expert can see there’s a problem And see the problem is half the problem And only an expert can deal with the problem Only an expert can deal with the problem
#19 |
I am not an expert unfortunately.
Nothing at all.
#20 |
There was a slight improvement.
I have to consider, however, because at least it's not ruined. https://public.bay.livefilestore.com...ilt.jpg?psid=1 https://public.bay.livefilestore.com...ont.jpg?psid=1 https://public.bay.livefilestore.com...ack.jpg?psid=1 https://public.bay.livefilestore.com...ink.jpg?psid=1
| So which Tek scope should I look for? | tonyptony | Equipment & Tools | 12 | 1st March 2013 07:26 PM |
| tek 454 | jechentau | Tubes / Valves | 2 | 26th September 2009 07:07 PM |
| Tek vs Tek | ak_47_boy | Equipment & Tools | 9 | 11th June 2007 05:27 PM |
| Selling my Tektronix 2467B Scope 400MHz 4 CH and Low Hours | spencer | Swap Meet | 1 | 20th February 2007 02:52 PM |
| New TEK Scopes | Bryan | Tubes / Valves | 22 | 25th November 2005 12:56 PM |
