Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 7th March 2012, 11:15 AM   #1
Sunsun22's Avatar
Default What does it mean by saying ±(1%+3)
I wish to buy a low ohm measuring equipment. It says the accuracy is ±(1%+3). What does this mean?
Old 7th March 2012, 11:32 AM   #2
hello, usually means +-(percent of reading + counts)
in this case for example if your display indicates 200
the "true value" sits between
(reading-0.01*reading-3)=200-2-3=195
and
(reading +0.01*reading+3)=200+2+3=205
Fabio.
Old 9th March 2012, 01:53 PM   #3
Sunsun22's Avatar
Default Meter reading
Thanks.
In this case, if I need the meter to read a resistor of 0.47 ohms, it may has a reading between
0.47 * 1% = 0.4747 + 3 = 3.4747
or
0.47 * -1% = 0.4653 - 3 = value below zero!
Therefore, it can never give accurate reading. Is my understanding correct?
Old 9th March 2012, 02:00 PM   #4
KatieandDad's Avatar
You pays for what you gets.
A reasonable DMM will give yo +/- 1% plus +/- 1 digit.
The highest accuracy is usually on the DC voltage range. You can use this to your advantage by simply using a potential divider to measure your resistors. Even better a Wheatstone Bridge.
Old 9th March 2012, 02:09 PM   #5
DF96 is offline DF96  England
3 counts (i.e. least significant digit), not 3 ohms!
Old 9th March 2012, 02:22 PM   #6
Originally Posted by Sunsun22 View Post
Thanks.
or
I'll assume that your DMM is 3 1/2 digit model, most of them are.
Therefore if you had a 100.00% accurate 0.47 Ohm resistor your meter might display:
0.47 +/- 1% = 0.478 to 0.462 Ohms
This also depends on the firmware in the DMM, does it Round-Up or Round-Down, will it remove the leading ZERO.
Old 9th March 2012, 02:33 PM   #7
Sunsun22's Avatar
Ah, then in my example on a meter with 2 decimal display, the 0.47 ohm will read somewhere between 0.5 to 0.44 ohm. Is this correct?
Old 9th March 2012, 02:39 PM   #8
0.47 + 1% = 0.475
Depending on whether your meters rounds this up or down could be
0.47 or 0.48 the the last digit could be up to 3 counts "OFF"
Which would give you 0.44 to 0.51
Similarly
0.47 - 1% = 0.465
Which would give you 0.43 to 0.50
So a perfectly good 1% -.47R resistor on your meter could read between
0.43 and 0.51 Ohms.
If you need better accuracy, just buy better resistors. The DMM will just serve to tell you that the resistors hasn't failed.
Old 9th March 2012, 03:55 PM   #9
Sunsun22's Avatar
Then, if an instrument has 3 decimal display, am I correct under the same accuracy, that the 0.470 ohm will have a reading between
0.470 + 1% = 0.4747 = 0.475 + 3 = 0.478
or
0.470 - 1% = 0.4653 = 0.465 -3 = 0.462
Therefore an instrument which has 3 decimal display will have a better accuracy than that has only 2 decimal display. Am I right?
Old 9th March 2012, 04:02 PM   #10
The more digits the better the accuracy.
Professional DMMs can have 6 digits or more, the most insignificant digit is then almost irrelevant.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
