Simple Capacitor ESR meter - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 5th March 2012, 12:42 AM   #1
Irakli is offline Irakli  United States
Irakli's Avatar
Default Simple Capacitor ESR meter
Hi all,
Here is the simple capacitor ESR meter which works very well.
My version of the ESR meter is based mainly on the project published by Lawrence P. Glaister at
Capacitor ESR Tester
There are several modifications though which I think are important:
1. I used the impulse step-down transformer to couple the oscillator+driver with the load and to reduce the output impedance. The transformation ratio is about 15:1 but it is not critical (you can use 10:1 for example). What is critical is to adjust gain and bias for Q1 to stay in linear region. I extracted the transformer from old Nokia cell phone SMPS charger.
2. I paid particular attention to Q1 amplifier biasing and gain. The key here is that Q1 should stay in the linear region all the time (no clipping). All the voltages are indicated on the circuit diagram.
3. I used higher oscillation frequency. Fo is around 233Khz.
The layout of the circuit is nothing special: ground plane and "ugly construction" (see photos).
My System
Old 5th March 2012, 12:53 AM   #2
lanchile's Avatar
Very nice! I have one that is build for fixing Hospital equipments. Take a look of this design.
Old 5th March 2012, 12:54 AM   #3
lanchile's Avatar
Here it is!
Old 5th March 2012, 12:55 AM   #4
lanchile's Avatar
again!
Old 5th March 2012, 01:23 AM   #5
Irakli's Avatar
Great! beautifully done . I believe I saw your design on the net and considered it as one of the prototypes.
Your circuit seems more accurate too, but high accuracy was not my goal here. I was also concerned with the usage of the op-amps for amplification at high frequencies (that's why you need three in series to achieve required gain).
cool!
My System
Old 5th March 2012, 12:43 PM   #6
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by Irakli View Post
Hi all,
Actually, it is not an ESR meter, it is a simple (scalar) impedance meter.
The only case it could display the esr is when the capacitor's self resonance frequency happens to coincide with the measurement frequency.
That said, it is certainly a useful piece of gear anyway.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 5th March 2012, 08:50 PM   #7
Irakli's Avatar
Agreed.
My System
Old 13th March 2012, 02:50 PM   #8
Do you have this in files with pcb or .LAY file?
I've tried to build this one someone modified to use a 9 volt battery and LED, but didn't have a 25K pot, I have Liner 5K, 10K and 15K Pots. or I didn't have the high voltage CAP for voltage protection.
So I'm thinking that might have caused it not to work. With the few I've tried to build, I could have bought two or three of the blues already, but it kind of takes the fun out of trying to DIY.
Bob
Old 13th March 2012, 02:57 PM   #9
Piersma is online now Piersma  Netherlands
Piersma's Avatar
Default Alternative
[DIY] LCR meter up to 10khz using AD9833 & dsPIC30F4012
Old 13th March 2012, 03:35 PM   #10
When I tried the link http://circuitcellar.com/microchip20...ers/third.html it gave an error "Page Not Found".
I tried the Hung kit. When the unit stopped reading ESR after 6 month's he said it was a solder joint. (After 6 month's.) Even sent photo's of the board to him, even gave it to a Computer Electronics class I was taking until funding was canceled so they could work with it and they all said it was the software. All solder joints were perfect. They put a scope on it and only the PIC was not working for ESR reading. So in order to fix the kit I would have to order the chip again since his program is propitiatory.
I'm not a designer, still trying to learn electronics, building test equipment was one way to try and save money. Trying to build the ESR meters have been the most difficult. All the other test equipment I build has been fine. Transistor/Diode tester, Old Oscilloscope from McGraw Hill, Dual Regulated Bench power supply, Signal Generator, Logic Probe, etc. have all worked first try. Just can't seem to build a workable ESR meter.
It's been said some have used their own program on the Hung kit, but I have never been able to find anyone that really has that has offered it on open source or I'd give it a try.
Originally Posted by Piersma View Post
ESR Meter cda75 Equipment & Tools 11 27th November 2009 02:04 AM
ESR meter schematic - Look at this and tell me.. silversweden Parts 2 6th February 2009 01:44 AM
ESR meter - Can someone please take a look at the schematic? silversweden Everything Else 2 1st February 2009 09:16 PM
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 11:13 PM
ESR meter schems?? RX5 Everything Else 0 18th May 2004 12:00 PM
Copyright ©1999-2017 diyAudio
