Best solder? where to buy? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 28th February 2012, 01:16 PM   #11
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
Originally Posted by stargeezerme View Post
Hi, curious to know what brand and type you use? normal or no clean/low flux?
Another thing worth mentioning is that I have a professional 5ltr ultrasonic cleaning machine, so should i be considering no-clean / water soluable type flux over normal stuff?
I realise that probably any decent solder will do, but it would be good to get the best variation from the off...
I have used Alpha Metals. I think the two rolls I used were Telecore and Reliacore solders. I think the latter is what I'm currently using IIRC. I bought them as they were the only 63/37 solder that I was able to get my hands on over here. They both work well for my uses.
I also have a small roll of solder that contains silver. For those odd jobs of soldering silver plated contacts (ceramic transducers and solar cells) as they don't dissolve the silver plated contact surfaces.
For cleaning flux, I just use IPA and a toothbrush.
Old 28th February 2012, 03:01 PM   #12
zigzagflux's Avatar
Another vote for Cardas quad eutectic. I get mine from Parts Connexion.
I also have a stash of Kester 63/37 for non critical or non audio use.
Old 28th February 2012, 03:14 PM   #13
Having measured the distortion quality of solder joints. I think multicore mildly active rosin core .032" 63/37 solder is probably the best all around choice.
I actually buy a locally made product. But those are the specs I look for. I find .062 solder kind of chunky except for some older style connectors and I do have .015 for small surface mount stuff.
I also have bar solder but some is used for the solder pot (tinning standed wire ends of cables) some is used for metal working (sealing shielded cans) and some gets painted gold for gag gifts!
Old 28th February 2012, 03:27 PM   #14
I just been reading a thread on another forum regarding the cardas, and it seems to get a lot of favour by those who have actually used it for a length of time ...
Cardas Solder - AudioKarma.org Home Audio Stereo Discussion Forums
Like you say, i think it be a good idea to source a couple of 1lb spools of that stuff from the US, and get some decent multicore 63/37 for general work and not bother with 60/40.
Good advice, thanks
Old 28th February 2012, 04:12 PM   #15
jackand08's Avatar
Hi stargeezerme,
Just my two cents on this, whatever you do don't buy lead free stuff! It is absolutely horrible and I have a roll of the stuff still sitting unused since I bought it from Maplin ages ago. Unfortunately, this is the only type that Maplin sells now, but I quickly found an alternative.
Although the general consensus is that 63/37 is better, I have had very good results with this 60/40 solder from Rapid:
Rapid Electronics Solder - 60/40 Tin/Lead
The 100g roll has lasted me for around 2 years (genuinely) and if you want to stretch to it, you could go for the 0.5kg rolls which would probably last for eternity! Also, even though it is only 60/40, as long as the board is free of oxidation and any fingerprints, then it gives excellent results-having a clean board applies to pretty much any solder anyway. Bearing in mind too, this is only with a basic Antex iron as well.
Jack
"Near enough is good enough, so good enough is best"
Old 28th February 2012, 05:06 PM   #16
labjr is offline labjr  United States
Best solder I've worked with is the original Wonder Solder like 20 years ago. I love the way it flowed. I guess it's changed and heard it was inconsistant. I now use the Cardas and like it. Makes a nice joint.
Old 28th February 2012, 05:24 PM   #17
Originally Posted by jackand08 View Post
Hi stargeezerme,
Hi there,
That's exactly the situation i want to avoid, hence asking for advice from experienced people, even though its yet another "best solder question".
I guess it all depend on the type of components you will be soldering as to what will be most suitable, in my case that will be new diy audio components, pre & power amps, speaker crossovers, binding posts, audio cables and some electrical stuff such as pwm speed controllers etc.
I'm hoping that soniccraft can oblige my specific shipping requests otherwise I may have to use a parcel forwarding service so that i have control over certain aspects. If anyone else is interested in buying a 1lb spool of that solder in the UK and combining an order together, splitting the costs then send me a pm and we can discuss it.
$53 (1lb) compared to 22 (100 g)
Last edited by stargeezerme; 28th February 2012 at 05:37 PM. Reason: spelling mistakes, d'oh
Old 28th February 2012, 09:28 PM   #18
Lead free solder melts starting at 430 F for tin silver and higher for other alloys. 63/37 melts at 361F. So for lead free you need more heat. It also does not flow like lead solders so you must use less for each joint. Then don't expect the joints to look the same as lead solder. They are not as smooth and shiny. So lots of folks who look at the joints and are used to lead solders often think the lead free connections are "Cold" when they actually are as good as you will get with lead solder.
The advantage of 63/37 is that it changes from liquid to solid faster than 60/40 this results in fewer "cold" joints. Of course those with decent skill will probably not notice a difference.
I pay under $45 for a one pound roll of flux core .032" 63/37. The lead free tin silver copper runs $112 a pound!
Old 28th February 2012, 09:52 PM   #19
I've ordered from Sonic Craft before. Nice guys. Sometimes takes a day or two for them to get back to you. They have a lot of goodies.
Old 28th February 2012, 09:56 PM   #20
nigelwright7557's Avatar
Have a look at RS Components | Electronic and Electrical Components and world-leading distributor of electronic and maintenance, repair and operations products. | Farnell United Kingdom
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Any non Hi-Fi brand solder better than Mcap and Siltech silver solder? mbl Analogue Source 23 24th November 2010 03:13 PM
Best solder to use rtarbell Parts 4 20th November 2005 01:05 AM
Group buy on Sn96.5 Ag3.5 solder... dkemppai Swap Meet 5 12th December 2003 02:26 PM
how do you solder? theChris Equipment & Tools 15 2nd January 2003 10:55 AM
Copyright 1999-2017 diyAudio
