Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 21st February 2012, 03:46 PM   #1
Default Are these multimeters good for audio work?
Heya fellows,
I'm considering getting a DMM. I've narrowed down three models but can't decide which to get. I would like to hear some advice from you guys. What are your thoughts?
Amprobe AM-250
Amprobe AM-250 Professional Electrical Multimeter. New in Box.
BK Precision 2407A Mini-Pro
BK Precision 2407A Mini-Pro, Autoranging. New in Box.
Instek GDM-394
Instek GDM-394 3.75 Digits ( 3 3/4 Digits) Handheld Digital Multimeter (3999 Counts) Single LCD Display. Brand New.
cheers
Old 21st February 2012, 04:12 PM   #2
Juergen Knoop's Avatar
I prefer meters with manual range selections. Auto range meters always suck cause of their response time!
Old 21st February 2012, 04:59 PM   #3
boyofwax's Avatar
The BK spec sheet does not really show the specs, or wether it has frequency and capacitance function. So I would choose between the Amprobe and Instek. The Amprobe has temperature measurement, the Instek not. The Amprobe spec sheet reads "professional ..." but they messed up voltage and current units.
If still in doubt, buy a cheap one at a local store. After a while you will know what to look for and what to appreciate.
Old 21st February 2012, 05:27 PM   #4
KatieandDad's Avatar
I've got two. One was over £100 from Fluke and the other less than £30 from a highstreet store. (Maplin in UK).
TBPO there is not a lot between them. They are as accurate as each other and the Maplin one has many more functions like Hfe and capacitance testing.
For audio use they are as good as each other.
A $10 special from Wallmart may be stretching this ideal. But you don't really need to go stupid with a professional device costing a lot of money.
http://www.ebay.co.uk/itm/New-VC97-3...item45f6bd1f03
http://www.ebay.co.uk/itm/FLUKE-77-E...item2a19c10a38
Old 21st February 2012, 06:47 PM   #5
Originally Posted by lloop9 View Post
Heya fellows,
Amprobe AM-250
Instek GDM-394
cheers
Maybe I am getting old. I have 4 multimeters that work right now -- two digital and two analogue. The small analogue I can slip into my pocket and head over to someone's house to fix the electrical whatever that is broke. Possibly the best $12 ever spent. A rather nice and modern digital one that I use when I am around the house or if someone has something a little more complex going. That one is probably the more flexible one with respect to ranges, temperature probe, and audible continuity (yes, set it to resistance and go from there, but sometimes checking a lot of wires and traces for breaks, a simple beeeeep is nice). The other digital one was got at a garage sale (Mastercraft for Canadian Tire) and it has a PNP NPN transistor plug in area which I have used about three times, but $5 is something you have for pocket change.
However, the one that I have used on everyone else's amps checking transformers and voltages going in and out, checking the voltage on a single phase 700V line into an HVAC turbine motor (this is where I learned that lower the amps, higher the voltage, smaller the size motor, the equivalent the torque, and less the heat... the motor was the size of a loaf of bread!) is a Simpson Model 955. This is the close cousin of the Simpson model 260. The upside is that this one can do it all. The downside, is that it is heavy and bulky as the body is thick cast aluminum.
I got mine for $30 -- it should have been more, but I don't think that the antique shop knew what they were selling. I would recommend this one or any of the older Simpson VOMs (Volt-Ohm-Milliameter) out there. It reads AC, DC, and the rage is from something like 2.5 V to 1,000 V AC or 1 V to 5,000 V DC (I don't think I will ever try that 5,000 V DC, c'mon... really, where am I going to find 5,000 V DC anyway?). Only problem is the unique 30V battery for the 10,000 ohm resistance range as I have to order a now one on-line. I have always wanted a Simpson 260 or a Hickok 215, but this one came up.
Do a google search on Simpson 260 as these are more plentiful. It ain't pretty, but it is pretty amazing. All my friends look at me and wonder what decade I time traveled from when I pull that one out, meanwhile the older guys (like my HVAC repair guy think that it is one of the best finds ever, but he has a Simpson 260 he still uses).
I have used auto-ranging and did not like the way the numbers danced and finally settled on a number that was close to my better meter. I like analogue more than digital because I can read scale and nothing jumps up and down in the AC.
I have broke or burnt out maybe 4 or 5 multimeters because they were cheap (made in China) or I let my father use them (who decided to check the AMPERAGE in the wall socket with my very nice Fluke -- I can safely say it ends with a shower of blue sparks).
If you really want digital multimeter and have cash to spend, then go Fluke. They make a dependable product, but not cheap and I have always wanted on before. Go check Greenlee (mentioned up there) as I have one and it has been reliable and comes with a lifetime warranty if that means anything for a company that has been around longer than I have been living.
That's the news and the way I see it.
Old 21st February 2012, 08:33 PM   #6
AMV8 is offline AMV8  United Kingdom
Hi
If you do not have a multimeter already I would start with a modest priced one; Maplin, Greenweld etc, at around £30 or $40.
If you find you get serious about electronics you will need more then 1 meter anway and you can buy an expensive one at that time such as a fluke, megger or avo etc.
Expensive meters are different than the cheaper ones. For example the accuracy, especially over time, will be better, particularly at low resistence values. For example you will find it difficult to measure resistence with any accuracy below 1 ohm with a cheap meter. But I would leave an expensive meter till later when you know for sure what you want.
Don
Old 21st February 2012, 09:06 PM   #7
DaveG is offline DaveG  United States
DaveG's Avatar
One of my meters is the AM-240. Works fine and the accuracy seems OK. I have a 25 year old aging 4.5 digit and the 2 compare well. It also does better than I expected checking capacitors. Only thing I do not like about it is the auto-off function. It will beep that it is shutting off even if it it is being used. Seems to me, an auto-off should respond after 15 minutes of no input, not just 15 minutes! (there is a manual override procedure that I perform almost every time I turn it on)
I paid around $50 on sale from one of the big suppliers 2 years ago. Also note that on mine anyway, the physical size of one of the internal fuses is incorrectly listed.
So measures well but has a few minor user issues.
Old 22nd February 2012, 01:01 AM   #8
Thank you so much for the advice guys. I think I'd rather spend my money on two for the price of one DMM, so I can use them for measuring voltage & current during amp construction. I'll check out your recommendations & try to get a good deal on ebay.
If not, I'll probably go for this $15 Instek, I would have like at least a 3 3/4 digit count, but I guess for the price 3 1/2 will do. It looks kind of cute too.
Instek GDM-350A
Instek GDM-350A 3.5 Digits ( 3 1/2 Digits) Handheld Digital Multimeter (1999 Counts) Single LCD Display. Brand New.
Old 22nd February 2012, 07:59 AM   #9
AmpliFire's Avatar
For audio work, you would like to able to accurately set the idle (bias) current, most often measured as a voltage drop across the power resistors in the output stage. This can be very low for Class B amplifiers, down to 5~10 mV or so. In other words, a DVM for this adjustment works should have a resolution (accuracy) of at least 1 mV (which ain't terrific) and preferably much better (say 0.1~0.2 mV).
You can determine the resolution looking at their specs. For example, if it is 1% of full scale, and the lowest DC voltage range is 400 mV (typical for these handheld DVMs), then it's resolution is 4 mV, not really sufficiant for adeqaute bias adjustments.
I could recommend to purchase a decent second hand Philips/HP/Fluke workbench (lab) DVM from that auction side; you'll find nice quality ones for way below $/€ 100, and which will do easily 0.1 mV.
Old 22nd February 2012, 05:33 PM   #10
macboy is offline macboy  Canada
You are confusing resolution with accuracy.
The resolution is strictly the smallest possible difference between two readings, almost always simply one "count" or least-significant digit. So on a 3.5 digit meter (+/-1999 display), set to the 200 mV scale, the resolution is 0.1 mV (and it can read from -199.9 mV to +199.9 mV). That absolutely does not imply it can take a reading to within 0.1 mV accuracy.
The accuracy spec (e.g. "1%") nearly always means "1% of the reading", not "1% of full scale". So, for example, if the reading is only 100 mV, then the tolerance is 1 mV. The catch is that there is usually an extra fixed inaccuracy specified, commonly +/- 1 or 2 counts for most ranges, and sometimes +/- a few counts at the lowest range. So if your reading is at the low end of the range, that extra 1 or 2 digits creates big % of inaccuracy. e.g. If you have a meter spec'd to "1% of reading +/- 5 counts" in the 200 mV range, and you are reading about 20.0 mV, then you have an inaccuracy of 0.2 mV (1%) + 0.5 mV (5 counts), or 0.7 mV, which amounts to 3.5% of 20 mV.
New To Multimeters MinesJA Equipment & Tools 8 4th May 2011 04:15 AM
UNITRON Multimeters applevalleyjoe Equipment & Tools 9 20th May 2010 11:46 AM
hfe on multimeters pdul Everything Else 4 22nd February 2010 05:33 PM
How long do multimeters last? bburl Equipment & Tools 18 17th February 2010 09:39 AM
Is this analyzer good for audio work ? Bernhard Parts 0 6th December 2003 06:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
