Pluggin a rated 80w soldering iron into a 40watt power supply - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 19th February 2012, 08:11 AM   #1
deuce42 is offline deuce42  Australia
Default Plugging an 80w rated soldering iron into a 40watt power supply
Hi
My apologies if this is a stupid question but I am trying to understand whether I can use two items I have together?
I have a Weller 24v soldering station power supply, I believe its rating on the back sticker says output: 24v/2amps max.
I also have a weller soldering iron which is rated at 80watts and runs on 24v.
Rather than buying a new iron or power supply, i am wondering if the supply I have can power the soldering iron, just at a lower amount (I am guessing 48w, eg 24x2=48)?
My concern is whether instead of only powering at 48w, instead the iron might try and draw 80w out of the power supply and hence blow the power supply - my house, myself etc in the process.
I realise this is a novice question but am slightly confused.
Old 19th February 2012, 01:58 PM   #2
Speedskater's Avatar
The power supply will be very unhappy. It's designed to output 24V but when connected to that iron, the supply doesn't have the horsepower to continue outputting 24V. So it will either shut itself off or blow it's fuse.
Kevin
Amplifier theoratical max rated output power based on supply voltage wwenze Solid State 13 26th September 2009 05:02 PM
looking for a soldering iron Shpoop Parts 38 8th September 2008 02:58 AM
soldering iron jaudio Parts 15 17th March 2006 07:22 PM
Need a power a 40Watt RMS Sub... Maples Solid State 33 25th May 2004 11:32 PM
What soldering Iron? sleepy Everything Else 27 23rd October 2002 10:37 AM
Copyright 1999-2017 diyAudio
