8 ohm test speaker load - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 19th February 2012, 12:30 AM   #1
Default 8 ohm test speaker load
Hello all,
I wand to test some 100 wat amps which are 8 ohm speaker outputs but don't have a dummy load. I measured my electric kettle which is 7.8 ohms and rated 1500 watts. I suppose it's a straight resistance load, with hardly any inductance to speak of. Is that resistance value close enough and acceptable to use as a load for testing power output.
thanks
Denis
Old 19th February 2012, 12:47 AM   #2
Pano is offline Pano  United States
Pano's Avatar
Yes Dennis, it will work. Just don't forget to put water in it!
I have used the little oil filled radiators (space heaters) as large dummy loads. Pretty much the same thing.
Old 19th February 2012, 12:54 AM   #3
nigelwright7557's Avatar
Its ok for testing power however the lack of an inductive load might not show up possible oscillation problems in the amp.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 19th February 2012, 07:37 PM   #4
thanks guys, I won't forget to put water in the kettle
Denis
Old 19th February 2012, 07:48 PM   #5
diyAudio Member RIP
Same with electric bar fires :
They make an excellent dual purpose dummy load / space heater.
rgds, sreten.
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 08:47 PM
2 ohm load on T-amp 3-LockBox Class D 1 22nd June 2006 12:38 PM
replicating a 4 ohm load leander Solid State 52 20th November 2005 04:05 PM
What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? The Paulinator Multi-Way 9 11th May 2004 07:04 PM
Zen.4 in a 4 Ohm Load? Rino odorico Pass Labs 8 18th September 2002 02:04 PM
Copyright 1999-2017 diyAudio
