Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 15th October 2012, 12:10 AM   #721
scott wurcer's Avatar
Originally Posted by davada View Post
Do you mean this one?
The Effect of u-Circuit Non-Linearity
on the Amplitude Stability of RC Oscillators
http://www.hpl.hp.com/hpjournal/pdfs...Fs/1960-04.pdf
Yes, the math here is very difficult remember this predates computers. Jim Williams sent me this with the comment that he thought this was the best analysis of a basic circuit concept that he had ever seen.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 15th October 2012, 12:48 AM   #722
dirkwright's Avatar
Originally Posted by dirkwright View Post
It's a very nice looking board:
[3rd round] AN67 Ultra-low THD 10kHz sine oscillator PCB Group buy. - Discussion Page 10 - diyAudio
He did a great job. It's designed to fit into a specific chassis. It's certainly the highest performance Wein bridge in the known world.
Dirk
However, builders are having problems with it, as mentioned in the discussions section. This doesn't look like an easy oscillator to make stable. They tried to use it for different frequencies also with not so good results. I imagine anything with 180dB of gain would be an oscillating nightmare.
Old 15th October 2012, 04:17 AM   #723
richiem is offline richiem  United States
richiem's Avatar
@dirkwright -- the gain and phase responses were specifically tailored for operation at 10kHz -- doing other frequencies would be a significant engineering project, I think.
Dick Moore
Old 15th October 2012, 12:05 PM   #724
dirkwright's Avatar
OK, Glen is getting a group buy together for his generator boards, which are part of his THD analyzer project I've posted on here before.
Who would like an ultra-low distortion audio oscillator PCB? - Page 1
He is in OZ.
Old 15th October 2012, 12:07 PM   #725
dirkwright's Avatar
Yeah, you are right. I don't know what they did with it to try to make it produce different frequencies. There's not enough detail in the thread that I can see.
Old 15th October 2012, 08:31 PM   #726
dirkwright's Avatar
Default Glen's oscillator
"The notch filter & distortion amplifier PCB is the board in the middle. The board to the left is the state variable oscillator board and the "dead bug" rats nest to the right is the prototype auto-tune board."
From Glen's website. The generator board looks nice and compact, perfect for a rack mount box.
Old 18th October 2012, 03:05 AM   #727
davada is offline davada  Canada
HI Scott,
Dick Moore and I were discussing this article recently. Both Dick and myself have worked with lamp stabilized oscillators using op amps. I have done it successfully with a state variable oscillator with remarkable results. Distortion levels as good or better than any other SVO.
Although Dick has witnessed the effect in an original Hp oscillator, neither one us have observed the effect with amplifiers having near pure spectral power.
Why is this?
David.
Old 18th October 2012, 02:52 PM   #728
HI Scott,
Why is this?
The lamp has two non-linearities, the thermal one and a voltage coefficient of resistance. Measure the lamp's distortion at 10kHz by comparing it to a resistor. The voltage coefficient of non-linearity is what actually stabalizes the oscillation with the thermal one setting the amplitude.
Try a sim with a perfect amplifier, Wein network, and a very small third order non-linearity in the amplifier. Kick it with a current pulse and the oscillation builds up to an amplitude determined by the non-linearity alone. The oscillator has a complex pair of poles that "walk" back and forth on the axis according to the instantaneous gain (gain of exactly 3 is on the axis) . The instantaneous gain is perturbed by the small nonlinearity and the amplitude is stable when the integrated gain over one cycle is exactly 3. Now keep decreasing the non-linearity and the amplitude keeps rising. A low frequency amplitude control is also needed.
I have tried to make a Wein bridge oscillator with no nonlinearity (<-140dB) in the circuit, indeed it never stabalizes except for a few seconds at a time.
Old 18th October 2012, 06:02 PM   #729
Interesting--do you knwo an explanation why the lamp has significant voltage coefficient? So far I've suspected that this is mostly a well behaved metal wire.
Samuel
Old 18th October 2012, 06:08 PM   #730
KSTR is offline KSTR  Germany
KSTR's Avatar
Default Residual Harmonic Distortion of Viktors Mickevics's 1kHz Oscillator
I had a chance to hook Viktors' 1kHz Oscillator on the AP and compare it against AP's own generator (direkt GENMON routing) and the Tek SG505. Test level was 2.7Vrms (Full scale on Victors')
No shielding of the Osc, and fed by lab supply.
The results speak for themselves, or in one word : INCREDIBLE!
Only with massive synchronuous averaging (4096 runs, checked for no/little loss of harmonics magnitudes) it was possible to see the distortion of this oscillator and it fares better than AP's by 10dB...15dB. The SG505 (with only 1024 blocks averaged) is far behind and plaged by hum which also seemed to disturb the autotracking of the notch filter of the AP.
File Type: gif AP_GENMON vs SG505 vs Viktors @ 1kHz, 2.7Vrms.gif (35.3 KB, 178 views)
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 19 21st January 2013 05:37 AM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2013 diyAudio
