| Equipment & Tools From test equipment to hand tools |
#621 |
So, we have the SG 505 phase shift oscillator, the HP 239A bridge T oscillator, and the Cordell SVO. All of them are buildable. I have no clue which to choose.
#622 |
If you have no experience at all in low THD generators I would suggest you to begin with the simplest one, just to experiment a bit and see what kind of problems you have to face to build and * measure * it - for reference, the full schematics of my clone is in post #255.
Ciao, L. |
#623 | |
What's the 1kohm trimmer near U1 for? and the other one by U6? Is the low input bias of a jeft opamp like the OPA2134 critical to the performance of your oscillator? If not, then there are lower noise opamps out there that could be used instead. Last edited by dirkwright; 9th October 2012 at 06:05 PM. |
#624 | |
ES9018 SABRE32 Reference 32-bit 8-Channel Audio DAC DNR (dB) 135 (mono) 133 (stereo) 129 (8ch) THD (dB) -120 |
#625 |
#626 |
Any experts on SG505's here on this truly exiting thread?
Both my colleage and I recently purchased one of these and we already tried a few things to improve the residual harmonics but to no avail. I don't exactly find the SG505 easy to understand in all details (AGC section, notably) but I don't claim to be an expert. Both units are still fully within spec (as verified on the AP2722), so it's really about tuning the "last bit out of them". So, anybody have a hint to known SG505 tricks (except for getting the hum down which is managable)? Not that I would expect the Tek guys didn't try tweak the hell out of it at their time, but after so many years there might be a chance that someone found ways to improve it with moderate effort. |
#627 | |||||
The schematic is only half the rent--bad layout can completely ruin performance. Quote:
* Frequency range 10 Hz to 100 kHz, in 4 decades * Amplitude range -60 dBu to +20 dBu * Harmonics below -125 dB for 20 Hz-20 kHz * Harmonics below -110 dB for 10 Hz-40 kHz * Harmonics below -100 dB for 10 Hz-100 kHz * THD+N (20 kHz BW) below 110 dB for 20 Hz-20 kHz * THD+N (80 kHz BW) below 100 dB for 10 Hz-40 kHz * THD+N (500 kHz BW) below 90 dB for 10 Hz-100 kHz * Settling below 1 s for 100 Hz-100 kHz * Settling below 5 s for 10 Hz-100 kHz * Amplitude flatness below 0.1 dB for 10 Hz-20 kHz (ref. 1 kHz) * Amplitude flatness below 0.5 dB for 10 Hz-100 kHz (ref. 1 kHz) Samuel |
#628 | |
Thanks for the website. Sorry for the dely in replying. I am back in work so cash rich but time poor. I remember trying to get a copy of Audio here in the UK for your article without success. My design goals were:- To learn KiCAD. Continuous tuning (in ranges) All mounted on a PCB for consistency. I wasn't bothered about settling time. I used a Phase Shift Circuit to minimise gain changes with frequency adjustment using unmatched dual ganged potentiometers. But this increases distortion with the high operational amplifier common mode signal. Sample and hold because I have had problems with loop stability in the past. High signal level for low noise but reduced linearity. If I designed another I would consider using an analog multiplexer with close tolerance surface mount resistors which are quite reasonably priced. Multipling DACs don't seem that linear. Lest see some more design ideas realised with test results. It's going to be hard to compete with AP because it's their job and they will have spent many hours which the amatuer can't do. |
#629 | |
![]() As far as the opamp is concerned: you need both high speed and high GBW to keep THD low at high frequencies, high input impedance, very low noise current density - in this particular application an OPA2134 performs definitely better (at low to mid freqs, at least) than, say, a LME49710, although this one has 1/3 the noise voltage density of the former. The original 239A employed an HA-2625, which is unfortunately classified either as obsolete or retired by Intersil - it was a bipolar uncompensated opamp featuring high speed (100 MHz GBW, > 60 dB OLG @ 100 kHz, SR 35 V/usec), high input impedance (300 Mohm), low noise current density (0.16 pA/sqrt(Hz)): these are not-so-common specs even in modern opamps, unless you are going to choose expensive beasts like the OPA637 - all in all, OPA2134 is a good starting point... L. |
#630 | |
I'm interested in looking at everything. If it's not too much trouble can you post it?
David. Last edited by davada; 9th October 2012 at 08:34 PM. |
| ultra-low distortion audio oscillator | geekysuavo | Analog Line Level | 16 | 26th March 2013 03:04 PM |
| Radford Low Distortion Oscillator Series 2 | audiomik | Equipment & Tools | 19 | 21st January 2013 05:37 AM |
| Low distortion oscillator? | rjm | Equipment & Tools | 30 | 4th May 2011 10:45 PM |
| Can we improve this low distortion sine oscillator ? | gaetan8888 | Solid State | 22 | 29th March 2009 12:30 PM |
| Simple, low distortion 1kHz oscillator | jackinnj | Solid State | 4 | 6th October 2003 03:58 AM |
